front suspension pics
Since it is just suspension I thought I would put it over here. This started as a Morrison front clip but was modified for the shockwaves. This is down and look at how little negative camber it has. I'm pretty impressed.
74 swb 71 2wd Jimmy 82 2wd Blazer |
Member since 2000
It wasn't designed to lay frame but it gets pretty low.
Garage Queen Material
i'm liking it
Livin' it up.
![]() Join Date: Nov 2001
dang that's a tight a$$ setup. looks killer
-Greg; Sold the 69 C20. It's off to a better home with more love! Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires. ![]() |
Seņor Member
What kind of hood hinge solution are you planning??
Dad's little helper
that look very good. that will look great when it is finished.
Progress = 0%
Looks great! Hey, can you raise the front of the truck to ride height and take those same pictures and post them for me?? I'd like to see how it all looks rasied up.
Thanks!
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
At point the hinges have not been discussed much. Steve made an initial attempt at something when the firewall was be shaved but quickly realized it wasn't what he wanted. Occasionally he mentiones it so I think he has something in mind. I am fairly sure it will come from the firewall though and will be made not bought.
This is a pic aired all the way up. I don't have pics at rideheight....sorry.
inside view......no the fenders won't be left like that.......they will be finished
The body is barely together and the door is literally taped on so don't pay attention to those gaps. Plus I really have to give it up to Rodney on this suspension. Morrison only makes a setup for double convoluted bags so there is more work here than meets the eye. He really did an awesome job on this. I only wish I had a good pic of the lower control arm. The mount he came up with for the shockwave is so simple and impressive. It wasn't simple to make but it sure looks simple.
Hey I found a pic of the lower A arm. Keep in mind this was just a bare A arm to start with. The bolt is not all the way in either. One side is basically a sleve and the other has threads. The bolt was even made for this application. I really get excited about the little things like this.
that looks so much like the future of my project! it's like seeing thru a time machine. i love it! i am still working on the body right now, but i got the metal for the new frame ready to go. did you use 2x4 tubing there? who bent it for you? or did you cut weld for shaping frame? hope to see more pics!
oh, on the hinges, Sachse Rod Shop has a nice design for the hood hinges. I have attached a pdf link. http://www.sachserodshop.com/pdf/170.pdf below is a pic of my project (73) ![]() Last edited by CustomChevy; 05-21-2003 at 10:59 PM. |
I Love This Stuff!
what tire size are you running up front? Looks sweet!
My Rides 1967 C10 In Pieces for now ![]() 1985 Ford B700 SourPuss Bus - BIG BLUE 2003 Silverado CITY WORKER YELLOW!! |
#15 |
That's a 245/40/20 tire.
Custom Chevy it is a 2x4 rail that was used. It started as a Art Morrison front clip with extra long rails. The rails extended to the point of the kickup for the rear end. The back portion was built at the shop. I have seen those hinges and they are nice units. Did I see a pic of your cab and you flattened the floor under the seat?
#16 |
chevelito
wow...i smell cover truck!!!
New deadline...when my son can drive. ![]() Aloha from Honolulu, HI |
#17 |
I Love This Stuff!
I've got another question for you brad2, I'm not sure about the laws in Oklahoma, but in Canada a vehicle has to be inspected before it can be insured and driven. One of the main qualifications is that welding on the frame on the vehicle voids the chance of insuring the vehicle. So the question I have is what are you planning on doing with your truck when you want to drive it and are the laws different down there?
Thanks For Your Time Jared ![]()
#18 |
Oklahoma has done away with vehicle inspections. The truck has a title so I don't think it would have been an issue here. Mostly they checked lights, tires, and glass before inspections were discontinued. I'd be screwed if I lived in Canada I guess.
#19 |
I Love This Stuff!
Damn
#20 |
Looking very nice brad2. Each time I see your pics I reconsider using modified stock truck stuff for mII or something similar.
Do you have 2 sets of TT2's or are you swapping back-n-forth?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-22-2003 at 02:49 PM. |
#21 |
How much did you give for the frame?
#22 |
i've been working on the floor for rust issues, but have not dropped the floor. i have considered altering the rear cab mount locations to be even with front mounts, but that is a way off possibility.
as far as the floor goes, i still need to check the rest of the metal and see if it will be salvageable. if it's toast, i will most likely flatten it and build some custom storage drawers for use as the seat mounts. ![]() |
#23 | |
#24 | |
Re: ???
#25 |
See, I have a question. I wanna eventually run some 22's on my '67. My question is, is there a front suspension that gets pretty good drop and also lifts pretty high. I like what they look like aired up.
![]() Brandon P.S. Your Blazer is beginnin to become a one of a kind. That's hard these days... Hope mine can be original one day. |
