Old 05-13-2010, 08:47 PM   #1
turner15
breaks lock up
So my right rear break locks up with the slightest pressure on the pedal.
Its an 80 gmc 25 with a floating rear end, not fun to drop off the drums to have a look.
Any ideas?
turner15 is offline   Reply With Quote
Old 05-13-2010, 09:02 PM   #2
3r!c84
Badass
3r!c84's Avatar
Re: breaks lock up
bad metering valve.
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 05-13-2010, 10:05 PM   #3
85burb
85burb's Avatar
Re: breaks lock up
Are they over adjusted. Mine did that. Backed them off a bit and no prob ever sence.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 05-13-2010, 10:15 PM   #4
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: breaks lock up
Look for oil on the backing plate, if the seal is leaking the shoes are contaminated and they get grabby
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 05-14-2010, 08:53 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
Re: breaks lock up
thats what happened to my 85.....axle seals leakin.....went for a whole rear rebuild....found i think the carrier was welded too(not why it leaked).....in my case case i found offset axle bearings to replace the old ones....
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 05-14-2010, 09:56 AM   #6
James McClure
One shot, one kill.
Re: breaks lock up
Mine has the same lock-up issue. Brakes are in good shape with no fluid leaks & adjusted properly. Height sensing valve is new and in correct position, BUT, it only happens once or twice when I first start out. The rest of the day it's fine. The drums will get a light rust coating when it's damp out and the truck sits for a few days. The first few stops cleans the rust off and the issue goes away. If you have a fluid leak and don't know if it's brake fluid or rear end grease, here's a trick. DOT3 brake fluid is water soluable and rear end grease isn't. Get some of the wet stuff on a finger and wet it. If it rinces off easily it's brake fluid, if not, rear end grease. This won't work with DOT5 though, as silicone brake fluid isn't water soluable. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 05-14-2010, 09:59 AM   #7
LONGHAIR
Re: breaks lock up
No matter how "fun" it may or may not be.....You still need to pull it apart and have a look. It could be anything from a seal leak or wheel cylinder leak to a spring failure or a lining problem. You could even have an E-brake sticking.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-16-2010, 08:58 AM   #8
Desert1957
Desert1957's Avatar
Re: breaks lock up
I know you guys will all have your own fix for this problem , but here is what fixed my truck. Yes it was something you would never suspect causing the problem. What fixed it was just having the rear drums resurfaced , Yes take them off have your local machine shop or anyone that has a brake lathe with the proper adapters cut them.
The only thing that I could figure is that shiney mirror like glaze the get over the years causes the first few stops to grab and in my case lock up, it would skid the rear tires. My truck would almost throw you through the windshield until they got a little heat in them. Trust me this is your problem if there are no fluid leaks on the shoe surface this will cure it!
Desert
PS: My 83 has the 8600 GVW pakage with the same floating rear you have
Desert1957 is offline   Reply With Quote
Old 05-16-2010, 09:57 AM   #9
Mike_D
Re: breaks lock up
I was having the same problem, here was my fix: rear axle seals were bad and the one the wheel cylinders was also bad. Additionally i noticed that I was losing a small amount of brake fluid. I thought it was leaking out the cylinder but in actuality it was leaking into the booster. That was also replaced, now it drives great.
my truck: 77 c20 with floating 14 bolt 4.10 gears
Mike_D is offline   Reply With Quote
Old 05-18-2010, 11:25 AM   #10
turner15
Re: breaks lock up
well my seals were done about 5 years ago, when I owned it the first time, I just re-bought it. My drums were turned then too. Guess I'm opening it up, once I find the wheel lock key!!!! dam kid I sold it to lost it...
