Old 05-13-2010, 11:32 PM   #1
mdwilf
mdwilf's Avatar
How Many PSI does the factory oil guage indicate?
I'd like to know if anyone know how many PSI the factory oil pressure guages are calibrated for? In other words, if it's at the far right hand mark, does that mean 60 pds oil pressure or 80 or what?
Thanks!!
What I do in my spare time:
http://rosebudsgarage.shutterfly.com
mdwilf is offline   Reply With Quote
Old 05-14-2010, 12:05 AM   #2
CE20934
CE20934's Avatar
Location: Help! I'm in an office park with its own network of freeways!
Re: How Many PSI does the factory oil guage indicate?
Most stock gauges are 60 PSI. If you have the gauge out, along the lower right edge it will say "60 PSI" or "80 PSI".
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man)
'95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis)
'07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed*
CE20934 is offline   Reply With Quote
Old 05-14-2010, 12:12 AM   #3
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Mine is 80 lbs, I found out when I had the cluster out. It is labeled right on the back like C20934 said. It probably depends on what motor you have and what pressure it was set up to run, my truck came with a 305 V6.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 05-14-2010, 12:24 AM   #4
leddzepp
Moderator
leddzepp's Avatar
C/10- C/30 trucks came with 60 lb oil pressure gauges. The C/40-up trucks came with 80 lb gauges. If I am wrong, LHM will correct me on this one.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-14-2010, 03:29 AM   #5
Jacfourteen
I wonder why my truck has the 80 psi gauge in it? I know that it is the stock gauge because my grandad owned the truck since 1971, and he never swapped it.
Old 05-14-2010, 10:43 AM   #6
StingRay
StingRay's Avatar
The only 80 psi gauges I've ever round came out of the C40 and larger trucks.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 05-14-2010, 10:49 AM   #7
too much stuff
Roadtrip!
too much stuff's Avatar
I have to agree with that. I have seen 60# gauges in bigger trucks, but never an 80#in a 10-30 series.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 05-14-2010, 12:06 PM   #8
turp mcspray
turp mcspray's Avatar
I believe 80lb were for big blocks. I don't know if they only used them in big trucks or not. I have pulled several dashes out of big trucks and they were 60lbs.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 05-14-2010, 10:26 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I have no first hand info on this, but I have been told the majority of big trucks, big block trucks, and v6 trucks got 80 pound, the much more common inline and small block truck got 60 psi.
