05-15-2010, 06:42 AM | #1 |
help with flywheel id.
i found this flywheel in a 92-98 1 ton truck. the engine and trans were allready gone. i was told it might be for a 454. the part# 14050525N Thanks,Woody
05-15-2010, 08:31 AM | #2 |
Re: help with flywheel id.
think it might be for a diesel.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
05-15-2010, 08:37 AM | #3 |
I dunno if it helps but the 400 SB and 454 BB Chevys are both externally balanced (Dont know about the Gen IV and V big blocks).
I had to order a new flywheel while building the 400 for my 71 Chevy, the part number was for both the 400 and 454 Chevy V-8's. Its easy to tell if it is, there should be a weight welded to the flywheel itself about 3-4 inches long just bellow the clutch wear surface. Another member may be able to tell by the part number but thats the easiest way I know of to tell visually. Just my .02
"When you were born, you cried and the world rejoiced. Live your life so that when you die, the world cries and you rejoice." [Cherokee saying] 2001 Dodge Ram Sport 1500 4x4. (old ride) 1987 GMC V1500 Sierra Classic ("new" ride) |
