05-11-2010, 12:51 PM | #1 |
Which fan shroud?
I am finally getting my 72 on the road again and need a fan shroud that fits. It is a factory a/c truck that originally had a 400 (long gone). When I got it it had a 350, the a/c has been removed but had BB 72 motor mounts. I changed to SB motor mounts which slid the motor forward a bit and must have dropped it because the fan now hits the bottom of the shroud. I got a set of correct pulleys and brackets and bought a short water pump. It also has power steering. Will any SB shroud fit correctly or do I need to get an a/c version? I plan on putting an aftermarket a/c system in when the time comes (unless that is a bad idea). They just seem to work well but are a bit pricey so have to save up some coin. Thanks for the help.
05-11-2010, 12:55 PM | #2 |
Re: Which fan shroud?
I have a good shroud from a 72 with sb and ac if you want to swap for the bb if its not cracked?
05-13-2010, 01:28 AM | #3 |
Thanks for the offer but I am going to hang on to my big block stuff in case I want to go that way some day. If you are interested in selling your shroud let me know.
Larry 1972 Chevy C20 Custom Camper 1968 Chevy Camaro RS 1980 GMC K5 Sierra Classic |
05-13-2010, 02:01 AM | #4 | |
Shake and Bake!
I have a stock 72 small block fan shroud that I had to ditch when I went to the serpentine/electric fan setup. If you need it I will sell it cheap, just make me an offer.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" |
05-13-2010, 05:11 AM | #5 |
Active Member
Can someone please show & tell me the differance in small block fan shrouds,
with and without a/c? Also did they use the same small block a/c shroud from 67-72 ? |
05-14-2010, 11:22 AM | #6 |
BLUE72SLAB... JUST THINKING OUT LOUD HERE. I LIKE TO USE BB 72 FRAME TOWERS WITH A SBC AS IT ALLOWS ME TO USE THE NEWER STYLE CLAM SHELL TYPE MOTOR MOUNTS. (MUCH STRONGER & EASIER TO LINE UP WHEN INSTALLING A MOTOR). DO YOU HAVE A BB FAN BLADE ON YOUR SB? I ASK THIS BECAUSE A SB FAN IS ABOUT AN INCH SMALLER IN DIA. THAN A BB FAN BLADE. SO IF YOU EITHER PUT THE 72 BB TOWERS BACK IN OR SWITCH TO A SMALLER FAN BLADE, IT'LL PROBABLY CURE YOUR PROBLEM. THE JUNKYARDS ARE FULL OF SMALL BLOCK FAN BLADES FROM ANY G.M. 8 CYLINDER. JUST TAKE YOUR TAPE MEASURE WITH YOU, & YOU CAN GET ONE CHEAP. I LIKE CLUTCH FANS MYSELF. JUST BE SURE NOT TO USE AN AFTERMARKET FLEX FAN (ASK ME WHY I KNOW) AS THE BLADES ARE SUBJECT TO SNAPPING OFF & BECOMMING A PROJECTILE. NICE LOOKING TRUCK BY THE WAY. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
05-15-2010, 10:46 AM | #7 |
John, thanks. I think I am going to put the BB towers back on so I can use the shroud, fan, shift linkage, etc. that I have. I will just need to switch my p/s pump bracket to one that is not attached to the motor mount.
