05-15-2010, 01:39 PM | #1 |
Deluxe door panels
I did a search and found that the ABS door panels I intended on getting from Classic Ind. are not the best quality. My customers original '71 Cheyenne panels are in good condition with the exception of the chrome around the wood grain peeling off. The only reason for looking at new ones is because of the chrome. Is there any way to make these presentable? If not, what are the best repros out there?
05-15-2010, 01:57 PM | #2 |
SWB 4x4 Collector
Re: Deluxe door panels
You might try a roll of chrome mylar trim tape after peeling off the existing chrome. Get some 3M 94 primer and brush it on the piece, then cut and fit the tape over the piece. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
05-15-2010, 02:38 PM | #3 |
Would that tape fit tightly around the ribs on the edges of the chrome border? The woodgrain itself is also not perfect, but probably usable.
05-15-2010, 02:55 PM | #4 |
SWB 4x4 Collector
You would have to experiment. You could maybe go to a vinyl wrap shop and see if they carry chrome vinyl material. It could be heat formed. Trevor
05-15-2010, 03:26 PM | #5 |
Try the thermo formed chrome from Alsa
05-15-2010, 10:49 PM | #6 |
Where can you get mylar chrome material by Alsa?
05-16-2010, 12:35 PM | #7 |
05-16-2010, 09:04 PM | #8 |
I believe that trim is stainless...have you tried polishing it? I use a die grinder with a 3" polishing wheel and green compound and it sure makes is look better than new!
05-16-2010, 10:51 PM | #9 |
i believe i have a set someware in my shop, & they must be pretty nice or i wouldn't have moved them across country with me when i moved. p.m. me if you can't find a set reasonable. john
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
05-16-2010, 11:24 PM | #10 |
SWB 4x4 Collector
Joel,right? The 70-71' door panels are different then the 72's. They have plastic trim that is part of the door panel that was vacuum plated chrome from factory. Originals tend to peel after all these years. Trevor
05-16-2010, 11:27 PM | #11 |
Future TOTM Winner
Could they be re-chromed??? Maybe thats out of the price range...
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
05-16-2010, 11:35 PM | #12 |
Thanks for all the responses guys. The owner of the truck has now decided to go with the standard style panels since the truck will be semi-custom. So anyway, I suppose we will try and sell these at some point.
