S10 frame guys battery location?
For those of you who've done the S10 swap on your AD's, where are you putting your battery? If I can't find a better idea, mine's going on the passenger side in the engine compartment. Getting close to having to wire mine, and the battery will be my starting point.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
Re: S10 frame guys battery location?
passenger side firewall is where mine is
Frenched mine about 4" down into the passenger's fender, think Jeffs51chevy did as well (I'm sure he'll chime in, and it's on his build thread.) Gives enough room for the heater core hoses to come out.
Cheers, Ted.
'51 Chevy Build - In the design stages Aut viam inveniam aut faciam - I will either find a way or make one. If you don't have time to do it right the first time, when will you... My new build - https://67-72chevytrucks.com/vboard/...70#post8958970 |
#4 | |
Trying to keep as much room available for a squirter tank and coolant recovery tank as possible, as well as the heat and A/C lines you've referenced.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler Last edited by BlueJeep; 05-17-2010 at 11:32 AM. |
Placed it about 1" from the side of the fender and about 1-1 1/2" from the firewall, perpendicular and was tons of room with the tires.
Ted. PS Will see if I can find a pic of it when I get home for ya.
'51 Chevy Build - In the design stages Aut viam inveniam aut faciam - I will either find a way or make one. If you don't have time to do it right the first time, when will you... My new build - https://67-72chevytrucks.com/vboard/...70#post8958970 Last edited by Thadious; 05-17-2010 at 02:34 PM. |
PLAN A: make custom inner fenders and core support simular to a S10 and place it at the right front. PLAN B: place it back on the frame rail back at the rear right fender behind the wheel.
Yup, 4 1/2 down and about 1 1/2 away from the inner/outer fender transition. As stated, tons of room. Search "S10 Swappers Battery Location ideas" posted in February. It should give you a couple more ideas. I will try to find a finished photo of mine. I know Atomsplitter has a great photo of the finished product.
Jeff |
