Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > Review Board > Vendor Reviews
Old 05-17-2010, 11:04 PM   #1
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: CPP Brakes SUCK!!!!!!!!!
That is a problem with the pads. I had that happen once on a 96 Chevy truck. I could hear excessive grinding and discovered that the pad was overlapping the rotor just like yours did. Since the pads were new, I didn't want to waste them. I ground the edge of the pad back with a bevel and the problem went away.
Since your are cracked from excessive heat, you will need to replace them. As 72K20 mentioned, I would get in touch with CPP Jeff. He has been going WAY beyond normal to offer great customer service.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-17-2010, 11:09 PM   #2
68 c10 ls2
68 c10 ls2's Avatar
I know what your saying but i went and checked the front pads and they are just fine with A LOT less wear than the rears. I did have to slam on the brakes once last summer and the rears locked up. So the poprtioning valve may be wrong to from them. (sending to much presser to the rear)
68 c10 ls2 is offline   Reply With Quote
