fuel sending unit
Hey guys. when i bought my truck just over a year ago, the fuel gauge didnt work. So i went to the classic car parts store and ordered a new sending unit. The fuel gauge now works, but not accuratly. After some research I found that the stock sender was 30ohm resitor and the one i bought was a 90ohm. Is there anyway to make this one work? I've called around and no one can get the proper one.
Thanks, btw its a 65 c20 |
Re: fuel sending unit
You could try running a 45 ohm resistor in parallel with the sending unit. Not sure if it will effect linearity. It will get you to the 30 ohms
1961 GMC Suburban Custom 1969 Short wide project http://67-72chevytrucks.com/vboard/s...d.php?t=535479 (SOLD) 1959 Apache fleetside (frame off in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=348746 1960 Apache short/narrow shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=350780 (SOLD) 1951 Plymouth leadsled project 2005 Corvette conv. Procharged 1969 Corvette stingray 2006 Cadillac XLR-V 1950 Oldsmobile 98 custom project |
It's Better With Nitro
I build new 0-90 ohm fuel sending units for the stock tanks, if you're interested. I have one on my shelf in my office ready to go. Check the link below for more of a description if this is the route you would like to go for the sending unit.
http://67-72chevytrucks.com/vboard/s...d.php?t=288717
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 05-18-2010 at 02:32 PM. |
I just bought a new 30 ohm one from Classic Parts of America...should be here tomorrow. I will let you know how it works!
You can also rewind the wire in the sending unit leaving out 2/3 of the wire that it came with, giving you the 30 ohm total resistance that you need. No B.S. it works, just did one on the '63 that I'm converting to fuel injection with a stock '91 tank and sending unit. I didn't have the money to have the sender reworked so I did it myself. Works perfect.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
