help! need exploded veiw of tilt column I cant get it apart
has anybody taken one apart? I cant get the tilt section off the column so i can redo it. Ive got the upper berings out and the tilt tension spring out, and cant see anything else that would hold it.
If you have pics, know how, or have any sugestions I sure could use them.
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
I'd like one too.
Theres about 4 different GM tool # J-XXXX that instructions recommend using for pulling these suckers apart. Just gotta wing it. Heres an exploded tilt. Good luck!
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. Last edited by Southpa; 05-02-2003 at 04:09 AM. |
454 club
Thanks for the pic
David 1965 Chevrolet c-10 454 automatic Custom bbw swb. 1965 Chevrolet C-10 swb (Sold) 1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's. R.I.P "I will miss you. 1967 Chevrolet C-10 6 Cyl Custom lwb 1939 Chevrolet Coupe, 350 v8 automatic. 1935 Chevrolet 2 Dr Standard in the works. 2015 Harley Davidson Street Glide. 2023 Chevrolet Stingray Z51 Convertible. I never want to grow up. |
Thanks for the pic, southpa
So it looks like its the cover that i cant get off. After that i should be able to pull the side pins and have it apart.
Anyone know how to get the cover off without wrecking it? Does it slide off? unscrew? or what. And thanks for the Help again!
I use a small screwdriver and hammer to tap the cover off. You will want to go around the cover to move it uniformally so as not to cock it. Penetrant will help it slide off easier as it is just a slight press fit.
Here is a pic. Jim |
Thanks jim, now I can actually get somthing done. Havent done much in the last two months
disassembling tilt column
After removing the cover and driving out the 2" pin that I beleive holds in the tilt steps or shoe, what's next?
I like to dissasemble my tilt column completely. With the 2" pin out everything is still tight in place. Could someone get me to where everything is visibly self explanatory, then I'll take it from there. Thanks, Luis |
That pin is a pain in the @ss to get back in after you get it apart.
If I had to do it again I would leave the 2" pin in. Pull the side pins and then pullback on the tilt lever to release and they should seperate.
Yes, I know
