Old 05-20-2010, 09:36 PM   #1
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
In case you were wondering...
What the inside of your hatch looks like:
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 05-20-2010, 09:37 PM   #2
red71cheyenne
Back in the sticks
Re: In case you were wondering...
That took about a week to get apart and I still broke it in a couple of places. Now to blast the hardware and put it back together. Hopefully it won't take a year to do that...
2011 K1500 Suburban
2014 K1500 Pickup
Old 05-20-2010, 11:23 PM   #3
Yukon Jack
Yukon Jack's Avatar
That's cool to see the insides!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-21-2010, 09:49 AM   #4
rads42
Now I know why mine works so poorly. Cool posting, thanks for sharing.
rads42 is offline   Reply With Quote
Old 05-21-2010, 10:34 AM   #5
orange72blazer
orange72blazer's Avatar
How did you get it apart? I need to do the same thing to mind.
1972 Chevy Blazer
1997 GMC Sierra
2009 Chevy Tahoe
orange72blazer is offline   Reply With Quote
Old 05-21-2010, 02:32 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Soooooooooo it really is filled with air sweet...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 05-21-2010, 02:34 PM   #7
red71cheyenne
Back in the sticks
Mine already had several cracks around the outside perimeter, so I just used the dremel, screwdrivers and brute force to pry it apart. I tried to be as easy with it as possible, but that fiberglass is tough. Hence the couple of broken spots on the outer sides. Some fiberglass filler will take care of it though and new paint will freshen it up.
2011 K1500 Suburban
2014 K1500 Pickup
Old 05-21-2010, 02:35 PM   #8
red71cheyenne
Back in the sticks
LOL, and dirt, bug guts and rust!
2011 K1500 Suburban
2014 K1500 Pickup
Old 05-21-2010, 02:35 PM   #9
JimmyFloyd
great post. i think I may have to do the same thing to mine to try and swap the hardware on it if it isn't easy to do otherwise.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 05-21-2010, 02:37 PM   #10
red71cheyenne
Back in the sticks
Really, the hardest part was drilling out the screws on the hatch supports. Those phillips head screws were not coming out! So I drilled them and then Mr. Easy out took care of the rest. Stainless and anti-seize will go back in.
2011 K1500 Suburban
2014 K1500 Pickup
Old 05-21-2010, 02:41 PM   #11
JimmyFloyd
yeah, I had to break the hatch supports off the rest of the top when I removed it cause they weren't coming out of either side. Been soaking it in PB Blaster daily in hopes that they will come off. My handle doesn't turn though.
Old 05-21-2010, 02:46 PM   #12
red71cheyenne
Back in the sticks
Mine was the same, you notice in the pic, the handle has been hacksawed off. Have a new garage door handle for it though, once everything is blasted and painted it'll go back in.
2011 K1500 Suburban
2014 K1500 Pickup
Old 05-21-2010, 02:51 PM   #13
JimmyFloyd
Lucky for me, i got a beat up hatch for free with decent hardware when I bought a lift kit of a guy locally. hoping I can transfer my stuff over. I was planning on splitting that one to see what was inside, but I may not have to now.
Old 05-21-2010, 02:53 PM   #14
red71cheyenne
Back in the sticks
If you can get the guts out with out splitting, I'd go for it. My guts wouldn't come out any other way and needed serious attention.
2011 K1500 Suburban
2014 K1500 Pickup
Old 05-24-2010, 12:58 AM   #15
woodymm3
woodymm3's Avatar
where you getting your parts blasted... i been looking for people to blast and coat parts around here but so far no luck finding anyone without having to spend a ton of money... thinking about buying my own.... but then i have to buy a compresser too... lame.
woodymm3 is offline   Reply With Quote
Old 05-25-2010, 09:18 PM   #16
red71cheyenne
Back in the sticks
There is a place in Poulsbo, Kitsap Powdercoating that will do it all. I just blast mine at the Auto Hobby Shop on Bangor tho, and spray paint. You can make your own powder coating setup with an old oven too. Eastwood sells the powder pretty cheap. I have a blast cabinet, homemade, but I didn't want to put it back together just to do these little pieces.
2011 K1500 Suburban
2014 K1500 Pickup
Old 05-26-2010, 12:08 AM   #17
woodymm3
woodymm3's Avatar
wow wasnt aware that they had a blaster at the hobby shop... what do they charge to use it and what are their hours... how big of parts can you blast... i am redoing my doors right now and i could sure use a blast cabinet!
Old 05-26-2010, 02:34 AM   #18
72gmcshorty
72gmcshorty's Avatar
how would you mate the two pieces back together? Would it be strong enough?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 05-26-2010, 03:14 PM   #19
red71cheyenne
Back in the sticks
Its like $3 an hour or something. The one they had at Bremerton was 6' long and about 2' wide. You can fit pretty big stuff in there, not a whole door tho. Of course, now the one at Bangor is down, they are waiting on new sand. I just called there to see if I could get my parts done today.
2011 K1500 Suburban
2014 K1500 Pickup
Old 05-26-2010, 03:15 PM   #20
red71cheyenne
Back in the sticks
It was put together with fiberglass to start with, thats just what I'll use to rejoin the two halves. I mean its all fiberglass to start with, so it shouldn't be a problem. I'll let you know when I get to that stage.
2011 K1500 Suburban
2014 K1500 Pickup
Old 05-26-2010, 05:55 PM   #21
woodymm3
woodymm3's Avatar
let me know when it gets back up... how big did you say the one at bangor was... are they going to reopent the bremerton one?
Old 05-26-2010, 10:52 PM   #22
69-72
69-72's Avatar
You could always use this stuff to glue it back together, its been working one year so far on the hatch I split apart. Should be able to get it at a boating store.
You will need alot of clamps though
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 05-26-2010, 11:22 PM   #23
woodymm3
woodymm3's Avatar
i think that is the funniest thing i have seen in a while.. it should be on one of those demotivational posters!
Old 05-26-2010, 11:23 PM   #24
Critter
Future TOTM Winner
Critter's Avatar
That's is an impressive clamp collections!!!
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 05-27-2010, 12:39 AM   #25
red71cheyenne
Back in the sticks
That is a bunch of clamps!! How long did it take that to set up? I was thinking of doing the same clamp thing, just with liquid fiberglass.
2011 K1500 Suburban
2014 K1500 Pickup
