how do you put a cab back on
how exactly do you take your cab off a cab roller and put it on the frame
Re: how do you put a cab back on
I use a few good friends with strong backs. Beer helps too. Just saying
1968 C10 SWB "Project Shop Truck" 1964 Impala 2DR Hydraulics 1933 Ford 2DR Sedan 1965 AC Cobra (Long Term Project) 1998 Viper GTS-R 1962 Chevy RampTruck (SOLD) |
Yep thats what I did. 4 people and rolled it right up to the back of the frame and put it on. Dont forget your cab mounts
Local Redneck Authority
a few people have shown their attachment you can buy or build that bolts on top of their engine hoist - it spans the inside of the roof. I also saw someone built brackets to bolt to the floor where the seat bolts up and picked up from there... Those seem like the safest way, but I just used 2x4s, 4x4s and ratchet straps to pull it off my trailer and onto the frame.
Truck and auto performance nut
If your doors are off... you can bolt 4 chains/straps to the floor at the cab mounting points and pick it up with a shop hoist/cherry picker
you can see here about to pick up the cab and move it over with the rest of the bodywork....before I realized I needed to spin either it or the other chassis around 1st. ![]()
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 05-19-2010 at 12:03 AM. |
have a overhead chain hoist.. makes quick work of cab swaps and/or repairs.
if your working with limited options.. fridge full of beer + friends works well.
* 1968 GMC Swb - 98% done (current restoration) * 1971 Chevy Lwb - Retired Dump Hauler * 1982 K10 Longbox - New Dump Hauler |
![]() Join Date: Oct 2005
Kinda a balancing act, but when you're a "one man show"....gotta do what you can!
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
Sacto Jim -great idea and your truck looks great.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
two post lift with the arms under the rockers work like a charm. The first thing I used mine for was to change a body on a 03 suburban witch used to be like a 5 or 6 man job at my shop I did it myself while the others were at lunch. Jim
thanks guys looks like another cab goin on safley soon i hope
I've swapped several cabs using a cherry picker with a 4x4 bolted to the top of the arm of the picker. I used the metal backer off old disk brake pads & put lag bolts into the 4x4 & bolted the other end of the metal to the arm of the picker where the chain bolts up. You can roll the windows down & use it with the doors on or with them off.
I learned the hard way to use wood or some other non skid material as the beam. |
