05-20-2010, 12:22 AM | #1 |
picture of a drag link angle please
i lifted my blazer, used a raised steering arm and im wondering if the angle is right. here is a pic of mine... could some please post a stock or a lifted proper drag link angle. im having problems with my steering and trying to eliminate things..
05-20-2010, 02:24 PM | #2 |
Re: picture of a drag link angle please
It should be level. You will have to add a dropped pitman arm to get it there. If you plan on any wheeling that requires articulation, you will be wanting a crossover steering in no time. LOL!
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
05-20-2010, 02:25 PM | #3 |
hmm, sounds familiar...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
05-20-2010, 06:08 PM | #4 |
Future TOTM Winner
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
05-20-2010, 10:31 PM | #5 |
i just bought a dropped drag link.. took it for a quick road test.. it was raining and still is, so it was hard to tell, but i think that fixed the problem. now i have a new problem tho.. i broke one of the grease nipples off.. 230 bucks well spent is there a fix for that?
05-20-2010, 11:02 PM | #6 |
Future TOTM Winner
Easy-out or bolt-extractor or whatever you want to call it might get it out.
05-21-2010, 12:13 AM | #7 |
People know me
If you bought a Z shaped dropped draglink then you wasted your money anyways.......... the tierods on them are junk. you should have gotten the dropped pitman arm that bolts onto the steering box for a little over $100.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
05-21-2010, 03:00 AM | #8 |
you should put a hiegher one but y think that to hi recomend to shange the steering shaft for one thats like a zig zag if it doesnt work your going to have to chenge the sterring box for a 2 wheel drive and put the sterring shaft across like the super dutys fords that way it turns better and its softer in the sand or what ever your on with the 4x4
cucharitas customs |
05-21-2010, 02:51 PM | #9 | ||
05-21-2010, 04:22 PM | #10 |
let us know how it comes out...
05-21-2010, 07:04 PM | #11 |
