Grandpa in the rustmobile...
Re: Need a 5 lug rearend, what're my options..
Will that work? :S Mdwilf? Thanks!
jbristo, your in TX lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
I've driven one that way for a few thousand miles & I'm doing it in the restoration I'm doing right now for a customer/friend. I was told that trick by someone who knows this era of trucks better than anyone I've ever met.
If you want to test my fix, measure the axles & see how far they are the same diameter - measuring from the end of the axle towards the "pumpkin ball" end. Then remove your old axles & measure the width of the axle bearings. Install the axle & then measure the gap from the bearing to the end of the axle & add the width of the bearing. If that total is less that the 1st measurement (distance that the axle is the same diameter) then you are good. You might be able to cifer all this out by measuring the wear marks on your old axles. Install your 2" wide brakes & put on the 2 3/4 drum. You will find it covers quite nicely. I hope this all makes sense. It's late for an old man!! Last edited by mdwilf; 05-22-2010 at 11:45 PM. Reason: I messed up |
Retired Air Force Veteran
![]() Join Date: Aug 2007
not sure of the year (seller never posted it) but maybe this will work
http://chattanooga.craigslist.org/pts/1711898392.html good luck
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
