05-21-2010, 02:04 AM | #1 |
Is there any reason I shouldnt shave the stake holes in my bed?
I am painting the bed on my 72 GMC 4X4 and the stake holes are a mess, who ever owned the truck in the past destroyed them, the last painter tried to fix the edges with bondo that fell off long ago. I have never used the stake holes in any of my trucks so I wont miss them. Are there any reasons I cant weld in some steel and get rid of them? Any tips on doing so?
I have a MIG and I am a decent welder, what kind of things do I need to be aware of to do something like this? Thanks! Aaron |
05-21-2010, 02:10 AM | #2 |
VA72C10
Re: Is there any reason I shouldnt shave the stake holes in my bed?
I don't see any reason why not if you never plan to use them. Just clean up the metal around it and weld in a patch, grind it down and paint!
Looking for a 67-72 swb or blazer project in or around VA. |
05-21-2010, 07:29 AM | #3 |
I cut 16ga pieces to fit and welded them in. It took only a thin coat of filler to completly hide them.
05-21-2010, 07:44 AM | #4 |
Redefining LowBudget
I have the same issue..I think I'm just going to get the push down tie downs....this way If I want to strap a cooler down or something I'll have it...also if you cover them you still have the box inside the bed...
05-21-2010, 07:50 AM | #5 |
when I repaint my truck those holes will be welded shut forever.....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
05-21-2010, 08:09 AM | #6 |
Under Construction
we welded/shaved ours. you can make your own patches or get them from member infanti .
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
05-21-2010, 08:42 AM | #7 |
Weld them over! The look is smooth and clean. The pockets below have holes in them which make excellent connections for bungy cord hooks to tie something off.
Mine is chopped, has a clutch, and a big block. |
05-21-2010, 10:10 AM | #8 |
PROJECT 7DEUCE
fill em in I made metal fillers for mine and they are now gone forever..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-21-2010, 10:23 AM | #9 |
I filled mine
on my 72 I had, I had eye bolts through the stake pocket box on the inside of the bed for tieing things too. Might want to do that before you weld them closed. |
05-21-2010, 10:31 AM | #10 |
Thanks for all the replies! They are going away today. I think I will weld a 3/8" nut in the bottom of the stake pocket before I seal them up, that way I can screw in an i-bolt or similar later if I need to.
Thanks again! Aaron |
05-21-2010, 10:49 AM | #11 |
I did mine about 10 or 15 years ago, time flies, welded in some home made pieces, skimmed some filler over them, painted and have never had a problem
05-21-2010, 10:52 AM | #12 |
"Hooked on Quack"
I don't see why not, people shave stuff all the time. What I like about that is most people would never notice I like subtle things like that.
Semper Fi, Kevin USMC |
05-21-2010, 06:56 PM | #13 |
I got them done, I am really happy with the look, I wish I had done it in the first place, I would have saved myself tons of work. I used some 16 gauge nail plates, I had to grind off a little to get them to fit but that was easy.
05-21-2010, 08:03 PM | #14 | |
Not to hijack the thread but do you have more pics of your yellow truck?
70 CST, 6.0/ 4L80E in the works. *Custom harness by 68 Short Step* Last edited by RaceAGMC; 05-21-2010 at 08:03 PM. |
05-21-2010, 09:10 PM | #15 |
05-22-2010, 01:50 AM | #16 |
05-22-2010, 08:35 AM | #17 |
05-23-2010, 01:57 AM | #18 |
I wished i would of??
The next one!
1950 Chevy 1500 1961 C-10 1969 C-10 1971 Chevelle 2008 Dodge HD3500 Tow Rig |
