05-21-2010, 08:03 PM | #1 |
changing ring and pinion
Hi, I have a 69 C/10 it has a 72, 12bolt 307 rearend. I want to change the ring and pinion to a 373. My question is, Do I need to change anything else. I seen a 373 0n ebay, but the guy says if you have a 307 carrier it wont work. i also need a 373 carrier. Any help would be appreaciated. Also I'm not deadset on the 373, I could use alil advise on the rearend size also. I have a 350 with a 350 auto, it's just dead on take off. around 60 or 70 when i punch it, it does very well. it sounds like a beast, but i need 15 mile straight to wound it out.
05-21-2010, 10:43 PM | #2 |
Too Dumb To Know Better
Re: changing ring and pinion
you will need a different carrier.
05-22-2010, 12:04 AM | #3 |
put in an overdrive trans with that 3.73...200-4r is a bolt in for a turbo 350. the effective top gear ratio will be around 2.61. that means you will have awesome highway cruising AND better get up and go. a lockup converter is another good idea....save every last rev and reduce trans temps.
my dad swapped his 87 burb 2wd over from a 3.08 to a 3.73. it already had OD and so he "maybe" lost 1mpg. the weight, aerodynamics combined with new england hills may have been too much for that soft rear gear to handle. it still pulls of 18mpg. i say...have your cake and eat it too! Last edited by capev86; 05-22-2010 at 12:06 AM. |
05-22-2010, 07:14 PM | #4 |
Its a Truck Thing......
Do you have the special tools to do this job? If you dont, dont mess with it. It may look easy but rear diffs are the one place you dont want to experiment with, or you will be setting on the road waiting for a tow......Also 3.73 with that drive train combo will be real bad on gas. Turning high RPMS at 60/70 MPH.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" Last edited by 71meangreenc10; 05-22-2010 at 07:16 PM. |
05-22-2010, 09:18 PM | #5 |
Thanks friends for taking the time to give me some input. I'm shopping around for the carrier and gears. I'm goin with the posi 373. Not really gonna drive anywhere but around town, gas mileage not a concern, unless it goes to $5 again. Smitty you have a sweet lookin truck, and the low'n slow truck is a looker too. I hope to post some pics of my 69 when I figure out how to do it. Thanks again
05-23-2010, 11:05 AM | #6 |
Thanks Jesse,
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
