Old 05-16-2010, 01:25 PM   #26
mattcrp1
mattcrp1's Avatar
Re: CA Engine Swap Laws/Question
I called the BAR and spoke to some one there and they said same year or newer and/or same size or bigger. As i understood you could not go smaller in engine size. And per what ia was told it made no difference to go gas to diesel. But like the CA DMV it is most likley subject to the person you spoke to that day.
mattcrp1 is offline   Reply With Quote
Old 05-16-2010, 07:09 PM   #27
Gregs71
Sounds like your on your way...
1995 GMC 4x4 1/2 ton
1999 Jeep Wrangler w/ 33's
68 camaro 350/350
1987 Chevy 3/4 ton 4x4
Suzuki DRZ 400s Dual Sport
1971 chevy long bed 2x4
194? Dodge 2.5 ton
1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455
1989 Chevy V30 crewcab dually 454/TH400
Gregs71 is offline   Reply With Quote
Old 05-17-2010, 03:10 AM   #28
JEM
Ironmonger
Originally Posted by Gregs71 View Post
one ref won't pass my bosses 454 tbi in his 85 jeep b/c the "frame was not meant for that big of a motor". Best bet is talk to the guy doing the inspection.
That wouldn't exclude the swap.
Basically, the engine must be of the same year or later and must have originated from a vehicle of the same class (that is, no 8600GVW TBI 454s in passenger cars or sub-8600GVW trucks.) It must be equipped with all OE smog equipment including cats in the original location (usually this means stock exhaust manifolds, sometimes something EOd for the engine's original application.) In his case, the engine would have to have been a half-ton truck 454 ('90-93 4554SS) with the proper part serial #s and all the smog equipment for that application.
It has nothing to do with the original type of engine, there are RX-7s running around legally with LS2s in them. Sometimes they get a bit persnickety about the details; I believe it's still the case that if you want to (legally) put a 351W in a Fox Mustang you need to have a block with the same part number used in the '95 Cobra R (the same block used in the '93-95 Lightning pickup and some other '90s half-ton pickups) because that was the only 351W passenger-car application of that era.
There are some vehicles, like Fox/SN95 Mustang V8s, that come in for such scrutiny from the state on smog-check results that many smog-test outfits just won't even touch them.
Vehicles 1975 and earlier are not subject to biennial smog inspection, but legally they're supposed to retain original smog equipment. I believe '66(?)-75 are still required to be smogged on transfer of ownership. There are still some counties in the state that do not require biennial smog inspection.
JEM is offline   Reply With Quote
Old 05-22-2010, 07:22 PM   #29
Goldfinger
Goldfinger's Avatar
Thank god for Florida no emissions check
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 05-22-2010, 07:35 PM   #30
leddzepp
Moderator
leddzepp's Avatar
Any pre-76 vehicle is not subject to a smog check even upon transfer of ownership.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-22-2010, 07:39 PM   #31
leddzepp
Moderator
leddzepp's Avatar
This is 100% correct.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-24-2010, 01:06 AM   #32
Gregs71
I was thinking about this topic. What about a crate motor from the dealer, or a rebuilt from Kragen? Is there no numbers on the block? If I put a crate motor (similar to stock) or kragen motor in my 1987, I don't think anybody would ever call me on it, would they?? Not sure how that could even be enforced.
68 camaro 350/350
194? Dodge 2.5 ton
Old 05-24-2010, 03:06 AM   #33
Kixwy2
Kixwy2's Avatar
This is one of the reasons I have a pre-1975...
FWIW, I bought my truck from a private party, transfered the title, and didn't need to do a smog check upon transfer. About 8 months later I did an engine swap in my truck with a brand new crate engine from Jegs. It's still a 350, but stronger and with a higher compression ratio.
Although I don't need a smog inspection every other year, right now I have most of the smog gear still attached. I do plan on getting rid of the air rails at some point. I think AceX is pretty right on in the requirements in CA.
I do have a buddy that tried to put in a 454 in his C10 when the engine blew, and it failed the test b/c the 454 wasn't available for his model/year. So the truck's been sitting for the last nine years behind his house, unused.
1974 GMC C-10; my new addiction
1998 4 Runner; daily driver
Kixwy2 is offline   Reply With Quote
Old 05-24-2010, 12:54 PM   #34
rfmaster
rfmaster's Avatar
Well, God has nothing to do with smog check, but lazy, good for nothing eco friendly bureaucrats make these decision when persuaded by eco-lobbyist and test equipment manufactures. In the end it all means very little as China, as of today, is the biggest (and growing) car market in the world with worst emission standards overall. India is not too far behind. Do not see too many eco-lobbyists there! No matter how they (state gov, CARB, EPA) try to spin this 'clean air' is just another form of taxation and jobs destruction. Once government starts taxing you on something it is next to impossible to 'ween' them off! Had enough already???
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 05-24-2010, 01:03 PM   #35
rfmaster
rfmaster's Avatar
What Model year is your friends truck? You can install 454 TBI system which was available from 87 - 95 on 3/4 and 1 tons (standard HP rating 250HP, but can be easily upped). Also, for 90-93 Chevrolet 454 SS was offered as a high performance full size pickup that mated the C1500 standard two wheel drive cab with an absolutely killer 454ci with 3 speed automatic transmission and a 3.73 rear axle ratio.
//RF
"The Beast"
Old 05-24-2010, 03:14 PM   #36
Fitz
Originally Posted by rfmaster View Post
Well, God has nothing to do with smog check, but lazy, good for nothing eco friendly bureaucrats make these decision when persuaded by eco-lobbyist .....
//RF
Yeah. Right. They're those same guys that Titled, Smogged and Licensed this specially constructed, one of a kind chassis running a 12 cylinder M-47 TANK engine. Take a close look at the rear view. Is that a Califiornia TAG? Why yes, it is!
They may be jerks but it's still possible to title and license a 32 Ford runninng a mid fifties Chrysler 392 Hemi!
Fitz is offline   Reply With Quote
Old 05-24-2010, 04:36 PM   #37
rfmaster
rfmaster's Avatar
'32 Ford had no smog requirements and is treated as such. As long as you have vin and title paperwork that states as original 1932 construction you can do what ever you like.
On the other hand specialty constructed vehicles (without pre 1960 VIN i.e. before smog requirements) is a completely different problem when it comes to titling. For full gory details see here:
http://www.dmv.ca.gov/vr/spcnsreg.htm
You have to camp out (or make an appointment) around DMV on the first day of the New Year for a chance for 500 spots allocated for such vehicles!!
http://www.dmv.ca.gov/vr/spcns.htm
It is a royal pita, but it is an eco-bureaucrats dream!
//RF
"The Beast"
