![]() Join Date: Jun 2009
window regulator help!
Having trouble installing the window regulator back in the window track in my 72' c10. Should I install the regulator in the track before installing the vent window? Thanks.
Between Trucks...
Re: window regulator help!
Regulator after vent. I think there's a right up in the FAQ.
Beat it to fit, Paint it to match... ![]() |
I always install the window regulator first, window, then vent. With the 72's longer shaft I believe that you will have trouble if the vent is installed first.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Between Trucks...
Jim may be correct on this. I did mine a while back, but could have sworn it was vent first.
vent window is last.
72 Cheyenne Super 80 Silverado Blazer 2wd |
