Old 05-24-2010, 07:43 PM   #1
brans72
Transmission ? on Inline 6
I was wondering if I might get some insight on this ? I have from you guys. I have a 67 C10 with a Inline 6 and 3 on the tree but wanna convert to automatic. I have a 350 automatic transmission and was wondering would it work and work correctly? I am not looking to build big power etc just be able to drive around ton and haul stuff with time to time. So will this work at all? Transmission came from 70 Chevelle and would be rebuilt first. Thanks in advance for any help/tips Brandon
brans72 is offline   Reply With Quote
Old 05-24-2010, 07:48 PM   #2
mbgmike
Re: Transmission ? on Inline 6
sure should be fine. just change out the pressure plate and add a flex
mbgmike is offline   Reply With Quote
Old 05-24-2010, 08:08 PM   #3
mbgmike
get the correct convertor that matches
Old 05-24-2010, 09:10 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
it'll work, they came from the factory with powerglides, TH350, and TH400's bolted to either inline, the 250 and the 292
Old 05-24-2010, 10:29 PM   #5
culp7
HickTown
culp7's Avatar
ttt any more indepth info on this? looking into it myself
1993 Ford Mustang Vert w/ 2.3
1969 Chevy C/10 w/350
1968 Chevy C-20 w/250
1976 Dodge Aspen W/ 225
2000 Toyota Tundra w/4.7
1987 Dodge Ram D-100 w/360
255/70-15
___________
(oo)══╬══(oo)
culp7 is offline   Reply With Quote
Old 05-25-2010, 07:13 AM   #6
brans72
Thanks guys! Now when you say correct converter which are you recomm exactly? Thanks for all info so far guys!!!
Old 05-25-2010, 08:58 AM   #7
Longhorn Man
one for a stock inline and TH350 will probably do fine.
Old 05-25-2010, 09:12 AM   #8
Shaky
Six in a row makes it go...
Shaky's Avatar
I owned a 70 Bel Air and a 65 Pontiac Le Mans - both had a 250 and turbo 350. It's a good combo.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 05-25-2010, 09:49 AM   #9
raycow
It will work, and work well, but this will be more of a project than you may be expecting unless you have done a manual to automatic swap before.
Your best bet would be to look for a donor vehicle, or you will be scrounging parts forever. Here are the MAJOR parts you will need: An automatic radiator, oil cooler lines, an automatic column or a floor shifter, shift linkage, a kickdown cable and bracket, a crossmember for the rear mount, a flexplate, and a starter. There were no TH350s before about 1969, so your donor truck should be in the 69-72 range.
The good news is that your stock driveshaft will work if you have a "short" TH350 (about 27" long). The bad news is that you will have to remove the bellhousing crossmember, and it is likely to be riveted in place.
If you still want to go ahead with this and have any specific questions (yes, I'm sure I missed some of the small parts), feel free to ask.
Ray
raycow is offline   Reply With Quote
Old 05-25-2010, 12:08 PM   #10
Shaky
Shaky's Avatar
Ray
This is true and is the reason why I don't convert manuals to automatics and vice versa. I know some people think nothing of it, but to me it's too much work. I'll change automatics to different automatics, and the same with manuals, but I'm done with conversions unless absolutely necessary...
Old 05-25-2010, 02:02 PM   #11
RichardJ
There is one other thing that you may have to do but I am not sure with the TH350. My '67 3/4 had a 3 spd and I put in a SM465 4 spd. My '67 floor pan was one piece with a low hump. I had to cut out the hump and use a bolt in tall hump from a 4 spd cab. I read that the TH400 also requires the tall bolt in hump. The TH400 is slightly bigger than the TH350 so again I am not sure there.
RichardJ is online now   Reply With Quote
Old 05-25-2010, 04:41 PM   #12
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Neither the TH350 or TH400 require a tall hump floor. Short is fine.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 05-25-2010, 07:05 PM   #13
brans72
I have no problem pulling a transmission in my garage and got plently of tools since worked on cars 9 yrs from GM,Honda and Toyota dealers and indepenant shop on the side. I just wanted to make sure if it was right move since I have one and what was need for most part. I do have trans,shifter column and crossmember are coming, with few other parts from another guy on another forum that is in my area who is trying to round other parts I will need up. Thanks for info guys your GREAT!!!! Brandon
