Old 05-15-2003, 02:46 AM   #1
chewed 71'er
Front/Rear Anti-Swaybar Compatibility
My truck has an original front-end anti-swaybar, am considering installing a rear one as well. Is a 1 1/8 inch too stiff for the rear-end? I don't what to expect in the way of handling, and don't think it should cause a stiffer ride. Any comments, suspension pros?
chewed 71'er is offline   Reply With Quote
Old 05-16-2003, 04:49 AM   #2
jimfulco
Rear bar should help counter the tendency of the truck to understeer (plow, push) under hard cornering. It should have negligible effect on the ride.
jimfulco is offline   Reply With Quote
Old 05-21-2003, 08:15 PM   #3
neonlarry
neonlarry's Avatar
A 1 1/8" rear bar sounds kind of big to put on with a stock front bar, usual setups are with the front bar slightly larger than the rear bar. The larger the rear bar compared to the front the more oversteer you will have, and since our trucks oversteer to begin with not a good idea.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 05-21-2003, 10:05 PM   #4
ocbaud
Garage Queen Material
my front and rear bars are the same size.
ocbaud is offline   Reply With Quote
