Old 05-24-2010, 02:22 AM   #1
Nova70
Nova70's Avatar
My Custom Center Console
Been building this all weekend. Took a while to finish because all I had was a jigsaw to use. It's not perfect but I think it turned out fairly well considering I didn't have a table saw. Also ordered a TView T92VGA Monitor to put toward the front of it. It's all touchscreen to plug my laptop into. I'm going to have it upholstered after the monitor gets here and I get it all set up the way I want.
Here's the hinge's for the top piece. My laptop is going to sit in here that's why I have fans. Gotta keep the air circulating.
What do you guys think? I still have a front piece to build but I have to wait for the monitor to get here.
'70 K10-- 4" lift on 35"s-- For Sale
http://www.ksl.com/index.php?sid=733...iew&ad=4578305
Nova70 is offline   Reply With Quote
Old 05-24-2010, 04:27 AM   #2
OARNGESI
OARNGESI's Avatar
Re: My Custom Center Console
Looks good how tall is the armrest
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 05-24-2010, 05:16 AM   #3
Nova70
Nova70's Avatar
Thanks! It sits 16" high. Feels perfect with where my seats sit.
Old 05-24-2010, 07:51 AM   #4
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Nice to see someone else take the dive on building a center consol...yours looks great !!!! since you used a heavy board like that take a sander and take ALL the square edges off it and give the upolstry stuff a try I did mine ..not perfect but it looks good..the material is pretty cheap just be sure to put at least a 1/4" pad under the materail
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 05-24-2010, 08:06 AM   #5
DZL1
One day.....
DZL1's Avatar
If you have access to a router with a quarter round bit, it will make the edges round not square and look nicer. Its easier than using a sander and will come out looking even. A half round bit would look even nicer but the screws are too close to the edge and the bit will eat too much of the wood and the screw head as well. Of course this all depends on what material your gonna use, Carpet, trunk liner, vinyl, etc. and if your gonna use padding or not. Just my .02.
BTW looks great!
DZL1.
DZL1 is offline   Reply With Quote
Old 05-24-2010, 08:27 AM   #6
Hottrucks
Hottrucks's Avatar
^^^ I agree thought about that after I hit the post button....
also look what I did under mine...looks like you have enough air for an 8 or 10" thumper..and that will keep the air moving under your lap top...lol
Old 05-24-2010, 04:29 PM   #7
Nova70
Nova70's Avatar
I already have 4 15's for my thumpin. Lol. Thanks for the comments. I think I might try the router bit on the corners. Maybe I'll try my own upholstery, I just don't want a lot of seams.
Old 05-24-2010, 04:52 PM   #8
POPO1984
POPO1984's Avatar
Looks nice
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 05-24-2010, 05:17 PM   #9
Hottrucks
Hottrucks's Avatar
looking at your console and the shape your going o need 2 seems one on each top edge...if you put a bead on it it will go very quick and easy..the material cost will be pennies so if it doesn't come out well you can always take it to someone...seeing what a good job you did on the box the rest will be easy..if you want any info on how I did mine pm me and I'll give you some pointers I learned...
Old 05-26-2010, 01:19 AM   #10
Nova70
Nova70's Avatar
Hottrucks and the $300 dollars I got quoted to have it upholstered for me talked me into giving it a shot myself. Here's the next step! Got 1/4 foam all around except for the back and in the laptop pocket. Waiting for the adhesive to dry up a little before wrapping. I have some material I'm going to practice with and keep on for a while. After I get a couple practice runs in and a little brush up with the sewing machine I'm going to go pickup some synthetic leather that matches my seats. I plan on doing the synthetic leather with red stitching around the edges. Should look good!
Anyway, here's the pics of it wrapped in 1/4" foam.
Old 05-26-2010, 04:37 AM   #11
Nova70
Nova70's Avatar
Well I've finished. Now I know why it's so expensive to have things upholstered. :p Pain in my butt. I guess for a first try at upholstery it's not to bad but It could be A LOT better. Eventually I will have it done professionally, but for now this works. It fits cups pretty good, it is a tight fit, but I can fit a 44oz. in there.
It has dirt and sawdust all over it. I'll wait for it to dry then give it a vacuum tomorrow.
Old 05-26-2010, 08:24 AM   #12
big_al_71
big_al_71's Avatar
It looks great and the best part you built it your self!!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 05-26-2010, 08:34 AM   #13
Hottrucks
Hottrucks's Avatar
well I think it looks good I know that after I did mine I felt the same way...If or when I do it again it will come out better....but by the time you sped $300 on material you'll be good at it and will have learned so much the next project will be a breeze
Old 05-26-2010, 09:05 AM   #14
ubtripn
ubtripn's Avatar
It looks great, don't change it. So the long piece slides under the seat right?
ubtripn is offline   Reply With Quote
Old 05-26-2010, 03:05 PM   #15
Nova70
Nova70's Avatar
The long part is the front of it. I have buckets from an '06 GTO. I will get pictures of it in the truck in a bit. I'm waiting on my 9.2" TouchScreen to show up so I can build a piece for it. The screen is going in the front of the skinny part just under the dash.
Edit: I'm also going to pickup some vinyl and practice sewing it all. I don't think sewing it will be to hard. I'll make a template that's about 1/2" taller everywhere then cut the material to that, sew it all inside out then slip it on. I'm sure it sounds easier than it's going to be but practice makes perfect right?
Old 05-26-2010, 03:08 PM   #16
1LoC10
Insert Title Here
1LoC10's Avatar
came out cool....good job
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 05-26-2010, 04:54 PM   #17
Hottrucks
Hottrucks's Avatar
when you cut the material place it over your console backwards and trace it that will be your sew line when its inside out..works great...your going to love it I can't wait to see it in the truck...
your going to want to step it up on the lid foam too (ask me how I know) I ended up with 1.5" dense foam on mine and its still a bit thin on the corner where you rest your elbow....since its just the lid wait till you get it in the truck you may want it to be a bit higher anyway to make it more comfortable...
Old 05-26-2010, 05:29 PM   #18
Nova70
Nova70's Avatar
Got it in my truck. Not to bad but I think everyone nit picks their own projects to much. Thanks for all the tips Hottrucks! I actually like the height as it is. A little higher might not be to bad, but being 6' 3" my arms are long. It will probably be a while before I get it done in synthetic leather with red stitch to match the shift boot.
Old 05-26-2010, 05:43 PM   #19
Hottrucks
Hottrucks's Avatar
Look killer.....
the funny part is your GTO seats look just like my BMW seats but your door panels are kick Azz I may hvae to steal that idea.... I wanted cup holders in mine but my amp is under the flat spot on mine and figured it wasn't a good idea..my next thing is to make up a set of kick panels....but its getting pretty black inside as it is....
Old 05-26-2010, 06:16 PM   #20
Quackaddict
"Hooked on Quack"
came out real nice, I think you have made my mind up, I was debating between buckets or bench, I have made consoles in the past and think I am gonna do it again..GOOD JOB
Semper Fi,
Kevin
USMC
Quackaddict is offline   Reply With Quote
Old 05-26-2010, 08:28 PM   #21
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Looks good, can't wait to see it with the monitor.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
