Old 05-26-2010, 09:19 PM   #1
66coffin
66coffin's Avatar
what panhard should i use?
I gotta 66 c20 that i swapped a 69 1/2 ton rear onto. the panhard mount from the frame and the rear end sit at different angles, i know it's because my old rear had a bracket that stuck way out towards the back and the new rear's panhard mount is right on the pumpkin. So, what do i do now?
'66 c10ish straight 292 power!
66coffin is offline   Reply With Quote
Old 05-26-2010, 09:26 PM   #2
daverod
SSN 706
daverod's Avatar
Re: what panhard should i use?
I'm thinking 4 link. No I don't really know. Maybe weld on a different bracket? Brothers sells an adjustable one for 61-72 comes with a bracket. Maybe look at it.http://www.brotherstrucks.com/
daverod is offline   Reply With Quote
Old 05-26-2010, 09:46 PM   #3
apachedaddy
apachedaddy's Avatar
The CPP pan hard bar i used, bolts to the old location on the drivers side of the frame. The bottom bolts to a braket that go's on the trailing arm under the axel on the passenger side. The bar is ajustable to make it the size you need to center your axel. Hope this helps you out some.
This is the kit i bought: http://www.classicperform.com/Store/.../6572CDTBK.htm
I think its CPPJEFF on this forum that can help you out with this.
66 short wide fleet sbw = Gave to my best friend
66 short wide fleet bbw
apachedaddy is offline   Reply With Quote
