GMC Paul's push on weather stripping
I got GMC Paul's push on weather stripping, and according to their website, "These push on, and will conform to the stock 45 degree mitered corner above the vent window assembly."
When I look at the weather stripping I got, it doesn't have a miter in it....it's just a continous piece. So did I get the wrong pieces, or do you just install it and the stuff will bend around the corner. |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Re: GMC Paul's push on weather stripping
It will conform. Just use a rubber mallet and lightly tap it in place as you work your way around with it. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
![]() Join Date: Apr 2005
Part number and pictures when you get it installed. TIA.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
69 Fleetside
![]() Join Date: Mar 2009
I have the same ones, after a good bit of work I got mine to fight pretty good, no wind noises inside either. My driver side door still doesn't shut easily, but the passenger side has softened a bit. Driver side still needs the butt bump after teh fact, with the windows up..and in rainy Washington - that is all the time...
Here's the part number
2660241 and the link http://www.gmcpauls.com/Pickup.htm the "old" glue on weather stripping took about 15 seconds to pull off, and the new weather stripping took a little work to get on. Like Wes said, I used a rubber mallet to gently tap it on. It took me probably 45 min to get them on, and the doors close fine (they are adjusted to close with the new glue on weather stripping) No test drive to check results or pictures yet |
I highly recommend the push on weatherstripping from GMC Pauls. I just ripped out the glue on and installed these. My advice to anyone out there..."DO NOT USE THE GLUE ON TYPE"...messy and constantly pull off. I called a buddy of mine who is doing a build up and told him the same thing. My issue now is I need to remove the excess glue because the push on weatherstripping is a little smaller than the glue on.
Great product and a must buy! |
I just installed the push on on my '70, and got a set for my '67 as well. They are really nice, but they don't cover as much around the edge on the inside.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
