Old 05-27-2010, 07:49 PM   #1
suville
suville's Avatar
UCA, New ball joints
For those of you who have installed new upper ball joints in the stock UCA, have you had to enlarge the hole for the rubber boot and joint to fit? I noticed as I attempted to install the new moog ball joint (PN K6124 in 71 C10) it wont fit unless I hog out the hole about 1/16 of an inch anyone else experienced this ?
suville is offline   Reply With Quote
Old 05-27-2010, 09:12 PM   #2
kev2809
low n' slo
kev2809's Avatar
Re: UCA, New ball joints
hmm, my upper bj's were k6024 (1967) and mine just went right in. i know they are different years so im not sure how much that will help you lol
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 05-27-2010, 10:54 PM   #3
tcb-1
Nothing to see here.....
tcb-1's Avatar
didn't have trouble in the past with stock uca either, Steve.
however, I bought a set of urethanes that were too small and had to darn near shoehorn them on!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 05-27-2010, 11:39 PM   #4
suville
suville's Avatar
Thats interesting, I checked the PN and Moog lists K6124 for upper and K6117 for lower for 71-72 I rekin I could just chuck up the carbide bit and open it up but wanted to see if anyone else run into this. Thanks guys!
Old 05-28-2010, 12:04 AM   #5
69 longhorn
As I remember, the ball joint went through the top, & the boot bolted up from the bottom side of the arm..... crazy AL
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 05-28-2010, 01:01 AM   #6
suville
suville's Avatar
I looked at it that way also and when assembled that way it fits, I was under the impression the boot needed to go on the joint so the grease didnt squirt out as there is no gasket, do the 4 bolts tighten it sufficiently as to eliminate that? Hey preciate all the input!
Old 05-28-2010, 08:25 AM   #7
custom70
custom70's Avatar
Thats how I insalled them on my 70 boot bolted from the bottom side. I have greased them and they seem to be fine, with no leakage.
custom70 is offline   Reply With Quote
