Manifold Clean Up
When I purchased my '72 the guy I bought it from threw in a a new Edlebrock Performer carb. After installing it I noticed the huge diff between the clean carb body and the oxidized alum Edlebrock manifold. Any tip or trick to clean up the manifold? Thx
Grandpa in the rustmobile...
Re: Manifold Clean Up
Blast it maybe
eagle 1 etching mag cleaner maybe..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Burnouts are therapeutic
should be glass beaded its the only thing I've seen really clean one ,don't sand blast it will rough up the aluminum and it eats away material
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
http://www.edelbrock.com/automotive_...cleantips.html
I have also used aluminum prep which is available at a automotive paint store |
if you wanted to spend a bit of time and remove it from your engine you can always sand and polish it
Thanks!
You can glass bead it and then clear it with a high temp clear too.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
