Old 05-23-2010, 08:53 PM   #1
rhodog77
rhodog77's Avatar
AD Fuse Box Location......s10 swappers
Question....
Where are you guys mounting your fuse box? I have a new EZ Wiring kit and hope to start wiring this week. I know some have located the fuse panel in the cab and some in the engine compartment. Any pix, tips, or advice would be appreciated.
Brian
"Get Busy Living or Get Busy Dying"
1970 P10 Stepvan
rhodog77 is offline   Reply With Quote
Old 05-24-2010, 12:05 PM   #2
Thadious
Re: AD Fuse Box Location......s10 swappers
I'm using the stock S10 harness and just reworking it, so mine will be a different setup. But I mounted mine right next to the brake booster with the fuses inside the cab, up high and out of sight as much as possible.
Good luck!
Ted.
'51 Chevy Build - In the design stages
Aut viam inveniam aut faciam - I will either find a way or make one.
If you don't have time to do it right the first time, when will you...
My new build - https://67-72chevytrucks.com/vboard/...70#post8958970
Thadious is offline   Reply With Quote
Old 05-24-2010, 12:35 PM   #3
OrrieG
OrrieG's Avatar
I'm going to mount mine on a swing down panel for access during wiring but tucked up out of the way on the left side of the steering column. some one else hear attached magnets to the panel and stuck it high up on the firewall. Before I had a mid 80's gm fuse box on a bracket screwed up high on the drivers kick panel. Somewhere I saw one mounted under the seat, I don't know if the ez wire harness dash wires are long enough to do that. They uses a console between the seats to run the dash wires.
Old 05-24-2010, 01:26 PM   #4
'58Patch
Not sure if this helps or if it is even possible, but on Scott's Hotrods they utilized this design and location. I am thinking about doing this myself.
It won't work as an image link, so here is the web link:
http://picasaweb.google.com/scottsho...16854665842450
View my truck's story here: http://67-72chevytrucks.com/vboard/s...d.php?t=402996
'58Patch is offline   Reply With Quote
Old 05-24-2010, 02:50 PM   #5
jeffs51chevy
jeffs51chevy's Avatar
I re-used the stock harness. I put it even with the brake booster on the outboard side. At first, I wanted it out of sight, but the farther along I get with this project, the more access I want if something goes wrong; plus a lot less slicing this way. If you use a harness that plugs through the firewall, do a test run on a scrap piece of sheet metal. Get the fit right, and then use the scrap as a template. It's much easier than tearing up you stock firewall. Ask me how I know.
Jeff
jeffs51chevy is offline   Reply With Quote
Old 05-24-2010, 03:35 PM   #6
1952ssr
1952ssr's Avatar
Reusing the stock s10 harness here also, mine was a '85 so it aint much different than buying a painless system. Not all that modern extra stuff to delete. And with the LT1 having a stand-along underhood fuse/relay box it will only be used for lights and other basic stuff. I plan on cutting the firewall from the s10 and then transferring the cut piece into the '52's firewall, in the same general area it was in the s10.
1952ssr is offline   Reply With Quote
Old 05-24-2010, 06:31 PM   #7
BlueJeep
BlueJeep's Avatar
Mine's a 95 s10 harness, so it was mounted in the dash by the door panel originally. I'm either going to mount it on a swing down panel or magnet mount (inside), as mentioned above. Plenty of wire for that with the 95 harness.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 05-24-2010, 11:20 PM   #8
smittster
In my 50 gmc I put my Ron Francis wiring harness under the seat. It is out of the way and easy to access.
smittster is offline   Reply With Quote
Old 05-25-2010, 09:31 PM   #9
54 jimmy
54 jimmy's Avatar
heres where i am mounting mine mid way up on the firewall next to the e brake pedal.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 05-25-2010, 09:55 PM   #10
rhodog77
rhodog77's Avatar
hey guys,
thanks for the info. I know that I will be mounting mine inside the cab. Im thinking the fiewall. I do like the idea of mounting the fuse box under the seat but Im not sure I have enough length to make it to the column. I know that EZ designed this kit to be mounted above the drivers side kick panel. I am going to get my battery mounted this week and then let the wiring fun begin!!!
1970 P10 Stepvan
Old 05-29-2010, 11:17 AM   #11
rhodog77
rhodog77's Avatar
So much for knowing what I know. After looking at my fuse box and setup, I think Im going to mount the box on the firewall inside the engine bay. I tried to set it up inside the cab but just didnt like how it was panning out. I will post some pix once I get it in.
1970 P10 Stepvan
