Old 05-28-2010, 04:44 PM   #1
chevymotocross
chevymotocross's Avatar
Should I plate this?
I cut these sections out for the lowering shackles I will be installing. Should I plate the openings or is it not necessary?
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 05-28-2010, 05:06 PM   #2
dv8customs
dv8customs's Avatar
Re: Should I plate this?
I wouldn't worry about it
dv8customs is offline   Reply With Quote
Old 05-28-2010, 05:10 PM   #3
Prerunner1982
Prerunner1982's Avatar
you know... if this will be a daily driver then road grime, dirt, sand, salt, etc will get up in there.. so if you have the tools/materials to do so, it wouldn't be a bad idea to cover those openings. So not so much for structural reasons, but more for rust reasons..
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 05-28-2010, 07:58 PM   #4
RandyP
Getting Old; Going Broke
RandyP's Avatar
Those are open ended bed braces, with holes in them to drain any water that gets in. Would be a total waste of time to close those ends up. It would probably actually cause more damage in the long run to close them, it would trap junk in there for sure then.
RandyP is offline   Reply With Quote
Old 05-28-2010, 08:25 PM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
When I dropped mine, I left a small amount of rail along the actual bed floor. I then made a couple of tubing pieces to fit into the rail and then bolted them to the rail. That way I still have support in that area of the bed.
Frank
Old 05-28-2010, 10:10 PM   #6
slugish
Slugish
Just sanded- cleaned & sprayed undercoating on mine > no rust after 7 yr,s.
slugish is offline   Reply With Quote
Old 05-29-2010, 11:33 AM   #7
westofb
I really hate wet sanding!
westofb's Avatar
Leave them open, there are openings between the top of the cross sill and floor ribs anyway. Leaving it open would allow for better drainage.
Jeff,
68 C-10
75 C-20, now a C-10!
10 F-150
westofb is offline   Reply With Quote
Old 05-29-2010, 11:36 AM   #8
chevymotocross
That's what I was thinking. Sealing them up could trap some of the junk that could get in there, causing it to rust. Plus, I'm just lazy.
