Old 05-30-2010, 11:58 AM   #1
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
My first set of rear air bags.....did I do okay?
I know NOTHING about air ride suspension, but after seening a guy in my town with them just on the rear, I wanted to do that to my truck. In a another year or so I will finally convert to disc brakes and want to go with a drop spindle. My truck needs another 2" off the front and back. I already have 6" drop springs in the rear and wanted to go with air bags for that extra amount. The frame is notched.
I was at a garage sale on Friday and a guy was selling a really nice set of Firestone overload air bags with brackets and lines. I did a good inspection and no rub marks or anything on them. I realize I will have to fab up my own mounting brackets which is cake but is there any reason why these bags won't work?? Oh yeah.......I paid $10 for both!!!!
prostreetC-10 is offline   Reply With Quote
Old 05-30-2010, 12:07 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: My first set of rear air bags.....did I do okay?
Great deal! Can't wait to see what it looks like slammed......
Hart_Rod is offline   Reply With Quote
Old 05-30-2010, 12:09 PM   #3
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
sounds like a great deal as they run ~$100 each if bought new. What size are they? (7" or 8" diameter probably) Most guys are running the 8" for the smoother ride and extra payload abilities. Where are the pictures?
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 05-30-2010, 01:27 PM   #4
prostreetC-10
My Carbon Footprint
hmmmm.......these bags are only about 6" in diameter. Is that not good? Doesn't seem like I would need much since no weight will ever be in the back and they are strickly to control ride height.
Hart Rod....it's not going to be slammed or laying frame at all. Just down a little more. I'd like the rear fender well to be just on top of the tire instead of the slight gap I have now. Also will keep people from really seeing the road grime that is under this "driver".
Old 05-30-2010, 01:46 PM   #5
Hart_Rod
Hart_Rod's Avatar
Got you. I forgot you were running 29" tall tires. I'm putting 31s on mine to cure that problem.....
Old 05-30-2010, 01:53 PM   #6
71swb4x4
71swb4x4's Avatar
Post a picture. These may be the smaller bags that are meant to complement a truck's existing suspension, not replace it.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-30-2010, 01:56 PM   #7
Jacfourteen
yeah sounds like they are helper bags. They might be alright if your not hauling a load in the back, but will probably ride pretty stiff because they will have to run higher pressure.
Old 05-30-2010, 02:09 PM   #8
prostreetC-10
My Carbon Footprint
Yes...this is why I refered to them as overload bags. I can see how the less volume could cause a harsh ride. Seems like the air pressure needed to get my desired ride height would be most critical. As long as I fab my mounting brackets so the bags are not at max height/pressure, wouldn't that help with the ride quality? Heck...this thing rides like a school bus with the tires on the back anyway. lol
Old 05-30-2010, 02:48 PM   #9
Jacfourteen
Yeah, it seems like you could make it work. You might have to play with it a little, but it probably couldn't be worse than the stock ride of my 3/4 ton. The guys in the suspension tech section would probably know more on this subject.
Old 05-30-2010, 02:50 PM   #10
Jacfourteen
Gotcha, I didn't see that the first time around
Old 05-30-2010, 03:40 PM   #11
prostreetC-10
My Carbon Footprint
LOL.....I was just being a smart A$$.
Forgot to post the pic.
