Salty Sailor
okay so on my truck when the headlights are on the passenger side parking light does not work, but if i turn on the right blinker it will blink on!
what is the problem?????
86 c-10 Custom Deluxe Savannah, Georgia |
Salty Sailor
Re: parking light is going crazy!!!
Pull the bulb out and try cleaning the contacts
1972 GMC C10 |
Salty Sailor
been there done that
Try doing the other one too lol
1972 GMC C10 |
try changeing the bulb...one filament may be broken.
Salty Sailor
i have also tried replaing the bulb, still unsucessfull
You check for voltage with the parking lights on?
I may be wrong but your signal and your marker should be 2 seperate wires. Sounds like signal works, marker don't. Broke wire? Broke wire going to ground? Bad contact at light assembly? Good Luck, I hate electrical problems.....
Salty Sailor
okay i will double check the wiring
#11 | |
Many electrical problems end up being ground related. Check your grounds.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right.
Salty Sailor
the ground is the same as the headlight ground and i cleaned it up.
still nothing....... come on guys what else could be causing my problem??????
All About the BOWTIE
Does your green turn signal indicator on your dash stay on.. or flicker when you go down the road.. without the signals being on?
CaliDude76 "... Being "SQUARE".. is where it's at...." ![]() Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... |
Salty Sailor
yea the green signal on the dash stays lit until i turn on the blinker then it will blink
#15 |
#16 |
OK.. mine did the same thing... what happens is that somewhere in your electrical loom there's a short.. or wires touching... which causes your green signal light on your dash to turn on.. though it shouldn't when you don't use the turn signals. The problem with mine was the wires that plugged into the parking lights was loose.. not meaning the socket that plugged in behind the light was loose.. but inside the connections.. try wiggling the wiring loom from the firewall.. all the way to the lights themselves.. maybe even disconnect it from he firewall connection.. and re-connecting it....
#17 |
Ok. I grabbed some pix so you can have a better idea, I have the same set-up.... The little black pig-tail on the top is what I was having problems with.. I wiggled that one.. and the light came back on.. it was real touchy... but it was the culprit... good luck
CaliDude76 "... Being "SQUARE".. is where it's at...." ![]() Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... Last edited by CaliDude76; 05-30-2010 at 04:48 PM. |
| Bookmarks |
| Tags |
| bucannon |
