1 ton and 3/4 ton ball joints the same size?
Does anybody know if the 1 ton and 3/4 ton balljoints are the same? The reason i ask is because i was looking at ECE's spindles and they list a conversion spindle for a 3/4ton to use 1/2 ton rotors and brakes and so on, but keep the 3/4 ton control arms.
It doesnt say anything about the 1 tons but if i remeber right the ball joints should be the same between 3/4 ton and 1 ton. Does anybody know for sure? These spindles sure would make it alot less work for a conversion. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 1 ton and 3/4 ton ball joints the same size?
The last time I checked on my 1-ton,... they were the same.
I actually have a set of thoses ECE conversion spindles in the box. That was my plan as well,... for the 1/2 ton conversion.
Your post is actually how i found out about the conversion spindles lol, Im glad i read it. This will make it so much less work to convert to a 5 lug wheel on my crew cab.
| Bookmarks |
