Old 06-01-2010, 08:31 PM   #1
Tow Me
Glen
Tow Me's Avatar
'91 Clip Swap & Hood Cable Length
I put a '91 Suburban core support/headlights/grille/etc. on my '81 Crew Cab and there is nice hole in the coor support that looks to be perfect to route the hood latch cable. My cable is factory and it is too short to go through the hole and connect to the latch. All of the parts catalogs I looked at do not offer a different cable ... at least from what I noticed.
Anyone ever run into this issue?
Glen Simpson
Severed Ties - Oregon
Roseburg, Oregon
  • 1983 Chevrolet C10 - Ginger
    Photos
Past Trucks
Tow Me is offline   Reply With Quote
Old 06-01-2010, 09:17 PM   #2
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: '91 Clip Swap & Hood Cable Length
This help? Is all I have for a photo here at home.
RandyP is offline   Reply With Quote
Old 06-02-2010, 12:39 AM   #3
Tow Me
Glen
Tow Me's Avatar
That's the hole I'm talking about in the core support. Does your cable reach your hood latch? Mine is a few inches too short... and even then the cable is tight across the inner fender wells.
Glen Simpson
Roseburg, Oregon
    Photos
Past Trucks
Old 06-02-2010, 12:42 AM   #4
westofb
I really hate wet sanding!
westofb's Avatar
Maybe they exit the firewall in different locations.
Jeff,
68 C-10
75 C-20, now a C-10!
10 F-150
westofb is offline   Reply With Quote
Old 06-02-2010, 07:53 AM   #5
RandyP
RandyP's Avatar
I have a 89 Burb clip, and an 87 truck. The routing is identical compared between the two and cables are exactly the same between the two. Basically pokes out the firewall, has a common tie down on the fender skirt that it shares with some vacuum lines, goes through that hole in the support, ends up topside through the hole and goes right to the latch. If anything, I'd say I got extra slop in the cable.
You're not trying to route the cable up by the washer bottle or between the fender and jack are you? My cable goes right over the jack instructions, but has enough slack to move it out of the way to read said instructions.
Old 06-02-2010, 10:12 AM   #6
Tow Me
Glen
Tow Me's Avatar
Any way I route the cable it wont make it to the latch. I'm going to the shop after work today and I have 2 other cables to try out. Maybe a PO changed the cable at some point...
Glen Simpson
Roseburg, Oregon
    Photos
Past Trucks
Old 06-02-2010, 02:26 PM   #7
bigarmzz
bigarmzz's Avatar
i couldnt begin to tell ya how many of the 91 front ends i've put on through the years, and i've always re-used the stock hood latch cable
1986 K10 swb 6" lift 37" tires
bigarmzz is offline   Reply With Quote
Old 06-02-2010, 02:36 PM   #8
Tow Me
Glen
Tow Me's Avatar
Thanks for all the info guys!
Glen Simpson
Roseburg, Oregon
    Photos
Past Trucks
