Old 06-02-2010, 05:01 PM   #3
73chevyman
73chevyman's Avatar
Re: Need some help gauge cluster lights????
sounds to me you need to put the cluster out and put in new bulbs..... there should not be any wires to your bulbs the green board on the back takes care of the wires..... cause if you had a wire to every little thing you wouldn't be able to put the cluster in due to all the wires....... pull the cluster you should have about if not more 8 little black plugs change every-1 and your problem with the lighting should be solved.......
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
