Old 06-02-2010, 05:23 PM   #9
hotrodsbyray
Re: Project "Popeye"
I am thinking of using the trailing arm suspension also. I thought about getting the used parts locally then using a CPP coil-over spring kit instead of airbags or original coils. From your measurements do you think that would work or do you think it would require a notch.
Keep up the great work!
hotrodsbyray is offline   Reply With Quote
