cab diff
we are changing cabs and I need to know if there is any
differences in between a 1/2 and 3/4 ton cab, if there is what are they. |
Almost Satisfied
![]() Join Date: Mar 2002
no differences between 1/2 and 3/4 ton cabs..
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
The cab mounts on the frame are different for 3/4 tons
Are the cabs of the same year? If not, there are diffs.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03) 1998 S10 short bed 2002 S10 Blazer 1942 Oldsmobile 1958 Massey Harris Pony 1951 Wife Killingworth, Connecticut May those who love us, love us, any of those who do not love us, may God turn their hearts. And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping. A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist. |
True enough there are some differnces such as small back window in 67 cab ., but big back window was an option in 67,
67-70 cab used a different type gas tank,then a 71-72 as a 71-72 cab has a vent tube in the cab for a charcoal canister under the hood.... also 71 - 72 cab has vent holes in the door frame near the vin tag. 72 cab has no raised area for the rear view mirror. Just a few differences I've noted, there are more but these listed are easy tell tale signs of a cab swap. Mind you some cab differences were carried over into the new year production. Rod
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
Hot Damn - Here I Am!!
I know that the big block and 4x4 trucks have the bolt in large hump floor. My friends 2wd Blazer with the factory granny geared 4 speed also has the bolt in hump. Do all the trucks with the 4 speed option have the big hump and what about the 3/4 and 1 ton trucks? All of them have the big hump floorpan?
Robert
My vehicles: '90 Silverado Sport '71 Chevelle SS Convertible '70 C-10 - My Grandfather bought it new - original un-restored |
huh ???
My 3/4 ton has the small hump... I thought it was just the 4 spd trucks...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
i found another difference.
when removing my 72 cab and replacing with a 71 cab i notced the 71 cab hung down lower in those two little parts tha run down parallel to the frame rails, hard to describe what im talking about but i noticed this since the guy who installed the th350 in my truck ghetto rigged the shifter linkage, their was a bolt sticking up through the frame rail that was holding it together, on my 72 cab it cleared this bolt, on the 71 cab it did not clear. also not sure if anyone mentioned above, 72 is first year for rear view mirror mounting on the glass |
The firewalls are different from 67-68 to 69-72's, also 72's have the screw in the door
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
Also dont know what year they started (I have a 67 small window) but some have a cargo light (?) on the back of the cab above the rear window.
67 Fleetside Shortie, small window, slip & slide tranny Upgrades--small block, tilt column, disc 5 lug conversion (front and rear), Future Projects--suburban gas tank under the bed, rear roll pan, better gas mileage (currently about 6-10 MPG) |
its all about the +6 inches
69 was the first year for the cargo light.
the high hump floors came in all 4 speed, all 4X4, all big block, and V-6 trucks, and blazer/suburbans. |
#12 | |
Robert
Yeah, I ment blazers/suburbans equipped with 4X4, big block or 4 speed.
I am now wondering about the V-6 cabs having high hups though.... My 69 GMC was a 305/Th400 originally. I thas a high hump floor, and is original. (still has original paint) There is a 69 Longhorn (GMC) with a 305 and a TH400 on e-bay right now....low hump. Interesting. |
Resident Curmudgeon
![]() Join Date: Dec 1999
One difference not mentioned is the throttle linkage. On 71/72 cabs, it's designed for the cable linkage. On 67-70, the linkage is a rod setup. Where the bracket for the pedal bolts is different and the 71/72 cab has a hole for the cable linkage not on pre-71 cabs.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
#15 |
I forget which years have what but the early models have a hand operated e-brake, later models use a foot operated e-brake.
#16 |
Gordo, that would be the 67/68 that have the hand brake.
#17 |
In '71 and '72, the drivers side door jamb got a black plastic vent that was not in there in 70 or earlier.
#18 |
chevelito
could i put the hand e-brake in a foot brake cab?
New deadline...when my son can drive. ![]() Aloha from Honolulu, HI |
#19 |
Thanks longhornmail, i figured it was somewhere around there.
jay-dawg, I'm doing the opposite, I'm putting a foot e-brake assembly into a 68 cab. The basic thing in my way is the fuse panel and junction box. In your case it may be less trouble.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03) 1998 S10 short bed 2002 S10 Blazer 1942 Oldsmobile 1958 Massey Harris Pony 1951 Wife Killingworth, Connecticut May those who love us, love us, any of those who do not love us, may God turn their hearts. And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping. A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist. Last edited by Gordo; 05-23-2003 at 10:55 AM. |
#20 |
I cant see why you could not just turn the fuse panel to an upward position like the 69-72 panel... should work. but you'll have some firewall insulation issues to work at.
