Old 06-03-2010, 08:46 PM   #1
spavinaw
spavinaw's Avatar
Door seal tape
I bought a new set of door weather strips for my 68 GMC today. I am new so dont laugh at me . I thought the strips would hold themselves on like the newer stuff. After getting it home I realize i need somehting to make it state put.
What do i use?
spavinaw is offline   Reply With Quote
Old 06-03-2010, 08:50 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Door seal tape
Weatherstrip adhesive.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 06-03-2010, 09:37 PM   #3
spavinaw
spavinaw's Avatar
Re: Door seal tape
Any thing specific in brand or place of purchase.
I hate rude behavior in a man.....I won't tolerate it - Cpt Woodrow F Call (Lonesome Dove)
1968 GMC C-10 (soon to be my oldest daughters)
2001 - 1500 4x4 ext cab - 150,000 miles
2001 - 1500 Burb - 233,000 Miles (wifes ride)
Old 06-03-2010, 09:45 PM   #4
JRE
Re: Door seal tape
I like the 3M brand weather strip adhesive. Comes on a tube and looks like yellow snot.
JRE is offline   Reply With Quote
Old 06-04-2010, 12:15 AM   #5
AustinScott
AustinScott's Avatar
Re: Door seal tape
do yourself a favor and find an early s10 and take the snap on seals off the door jams. This will save you many hours of labor and the feeling of cheap aftermarket seals that do not seal very well after a few good hot days.
the s10 seals are almost a direct fit, they just need minor trimming to make fit great, they seem to seal a bit better than stock, and go on a 100 times easier!
but if you must attempt a glue/snot job with some stock seals, just remember a few things.... go slow & do a little section at a time letting it tack real good before moving on, this approach can reward you with good glued in seals, but with that said, they are only as good as stock glued in seals ever where.
I found this information on this site, do a search, I did, and was truly surprised how effect this information was.
Scott
AustinScott is offline   Reply With Quote
Old 06-04-2010, 03:06 AM   #6
tim21391
tim21391's Avatar
Re: Door seal tape
while your doing it i always liked to hold it up with scotch tape so it will stay put then shut the door while its still tacky so the door will help cure the glue
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 06-04-2010, 07:55 AM   #7
bigsnookmaster
bigsnookmaster's Avatar
Re: Door seal tape
3M weatherstrip adhesive, and it comes in black.
bigsnookmaster is offline   Reply With Quote
Old 06-04-2010, 09:52 AM   #8
Ackattack
Ackattack's Avatar
Re: Door seal tape
GMC paul sell some push on weather strip seals for our trucks. I removed my brand new glue on seals just the other day to install these.
Ackattack is offline   Reply With Quote
Old 06-04-2010, 11:01 AM   #9
tqlspec
tqlspec's Avatar
Re: Door seal tape
I believe the GMC Pauls are actually out of Dodge Dakotas. Don't know what year. I installed in my 72. Been in 3 years and they were fairly easy to install using a rubber hammer.
tqlspec is offline   Reply With Quote
Old 06-04-2010, 08:20 PM   #10
LockDoc
The Older Generation
LockDoc's Avatar
Re: Door seal tape
If you are really cheap like me you can go to the salvage yard and get 1987-97 Dodge Dakota slide on weatherstrips. You will need to take a phillips screwdriver, small hammer and a small pry bar to get them off. You can usually get a nice pair for under 10 bucks... You have to cut about three inches off of them.
LockDoc
Leon
Old 06-04-2010, 08:26 PM   #11
cpetersen
cpetersen's Avatar
Re: Door seal tape
The black 3-M adhesive is the best. Just don't get that stuff in your hair. lol
cpetersen is offline   Reply With Quote
