Closed Thread
Old 06-03-2010, 01:52 AM   #251
El Jay
Gone to greener pastures
Re: What did you do to your truck today!
Tracked down an electrical problem in the tail light circuit & fixed it. No more blown fuses, at least for a while.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline
Old 06-03-2010, 12:47 PM   #252
CG
BlahBlahBlah
Moved my truck back down the driveway a few feet so my honeys dad could get around it when he mows our yard...then I went back in and watched TV =)
CG is offline
Old 06-03-2010, 03:49 PM   #253
Rat Bastid
Rat Bastid's Avatar
today i went and picked up new outside door hamdles and driverside hinge pins
Rat Bastid is offline
Old 06-03-2010, 05:01 PM   #254
Critter
Future TOTM Winner
Critter's Avatar
THAT'S WHAT I'M TALKIN BOUT!
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline
Old 06-03-2010, 06:15 PM   #255
vectorit
What?
vectorit's Avatar
Just finished hand waxing the burb.
Still need to go and do the roof though.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline
Old 06-03-2010, 06:36 PM   #256
67Slider
67Slider's Avatar
Talking Re: What did you do to your truck today!
My Daughter, Hanna and I removed the radiator, battery tray, grill support and a bunch of hoses.
[IMG][/IMG]
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 06-03-2010, 06:44 PM   #257
big mike71
big mike71's Avatar
I put on new header gaskets and went for a criuse.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline
Old 06-03-2010, 08:58 PM   #258
spavinaw
spavinaw's Avatar
I bought new door mirrors and weather stripping. Put the mirrors on. Didnt realize I needed adhesive to make the weather stripping stay in place.
I hate rude behavior in a man.....I won't tolerate it - Cpt Woodrow F Call (Lonesome Dove)
1968 GMC C-10 (soon to be my oldest daughters)
2001 - 1500 4x4 ext cab - 150,000 miles
2001 - 1500 Burb - 233,000 Miles (wifes ride)
spavinaw is offline
Old 06-03-2010, 09:00 PM   #259
Hubscrub
Cruzin
Hubscrub's Avatar
painted wife's rad. support yesterday, painted hood hinges today and fixed heater box come off the hook i had it on a made a quarter size hole in it after i had it together and painted
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline
Old 06-03-2010, 11:00 PM   #260
americanmusc1e
americanmusc1e's Avatar
checked timing and pulled some vacuum advance timing and....
CRIED.... because there was water all over my carpet
I have a leak under my cowl.........I have to take the whole frontend off and more to fix it........I had it apart last year when I had the fenders off and I neglected to fix it
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline
Old 06-03-2010, 11:10 PM   #261
ERASER5
ERASER5's Avatar
I finally installed my hitch. It tucks a little deep under the bumper, but it is solid. Wired and ready to go. Now if only the engine ran...
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline
Old 06-03-2010, 11:31 PM   #262
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
american muscle where exactly is that spot at?
John
1999 Toyota Tacoma 4x4
oldblue1968chevy is offline
Old 06-03-2010, 11:32 PM   #263
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
...finished getting my motor ready to pull, pulled front coil springs and most of steering.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline
Old 06-04-2010, 12:07 AM   #264
americanmusc1e
if you take off the cowl panel and look down in the cowling air vent area directly over where the heater core is you'll find it (I hope that makes sense)
I also have these spots on both sides in the channel under the hood-to-cowl seal, and directly beside the other one
-- Josh
Old 06-04-2010, 12:31 PM   #265
Lippyp
English Chevy Owner
Lippyp's Avatar
Started her up, listened to the misfire, realised I have more work to do than I thought to get her back on the road and then put the cover back on!
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline
Old 06-04-2010, 07:12 PM   #266
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
Got the axle in. Shocks and adjustable panhard bar too. Still need to to the brake lines, driveshaft.
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline
Old 06-04-2010, 07:33 PM   #267
68GMCCustom
...pulled the motor and trans...along with the front steering and front coils.
Kurt -
Old 06-04-2010, 07:37 PM   #268
vectorit
What?
vectorit's Avatar
Waxed the roof the the burb.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline
Old 06-04-2010, 08:13 PM   #269
Those are about the size of Rhode Island!
Well at least it feels that way when you are doing one.
Palf70Step is online now
Old 06-05-2010, 12:31 AM   #270
bjinx
bjinx's Avatar
Changed the oil, fuel fliter and PCV valve. Finally made a spacer to raise the tranmission up and get the drivers side header pipe off of the transmission crossmember. A few more things to check tomorrow, preparing for about a 250 mile trip Sunday to Billet Proof Show in Giddings, Tx.
bjinx is offline
Old 06-05-2010, 12:50 AM   #271
T/C
T/C's Avatar
Painted my steering column my interior is now done other then finishing the wiring in the dash!
So much closer to my new motor and tranny !
T/C is offline
Old 06-05-2010, 09:04 AM   #272
vectorit
What?
vectorit's Avatar
Thanks for understanding! I was thinking people would be saying to themselves: What, wax a roof? what so tough about that!
yea, doing a burb with rubbing compound is like doing 3 or 4 pick ups! Plus, with my burb I need to use a ladder to do everything from the hood up. I know but after wards - so nice!
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline
Old 06-05-2010, 09:05 AM   #273
CG
BlahBlahBlah
Well come on man, post up some pics of all your hard work!
CG is offline
Old 06-05-2010, 11:29 AM   #274
Hubscrub
Cruzin
Hubscrub's Avatar
installed 1 new fender 1 oringinal, new rad. support on my wife's 67, and put new seals in the heater box
Proverbs 3:5,6
Hubscrub is offline
Old 06-05-2010, 04:41 PM   #275
swierker
swierker's Avatar
Installed a new windshield washer pump. Moved it from inside the cab to the firewall. NOW it will pass inspection...
swierker is offline
Closed Thread
