01-01-2009, 03:22 PM | #1 |
How Long Did Your Factory Brakes Last
With in a month changed all brakes pads on my 2005 4x4 2500 HD 72k miles Then on my wifes 2004 Denali 83k on it .This was the reason my last three pickups have been chevys.Had the new dodge in 1995& 98 brakes fell off at 36k.What kind of milage do you get out of yours.
01-01-2009, 03:31 PM | #2 |
Re: How Long Did Your Factory Brakes Last
I'm at 40K on an 05 Tahoe and they still feel like new...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
01-01-2009, 10:48 PM | #3 |
i have 94k on my 01 with a 6'' lift and 35'' tires and i just did rears fronts are still good
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
01-02-2009, 08:11 AM | #4 |
i replaced the fronts on an 01 the other day had 84k on them
01-02-2009, 09:53 AM | #5 |
i told my mechanic just replace them with oem pads .this truck will have another 25 k put on it then i will turn it over to one of my workers to go to job sites,then the destruction starts,dent here a ping here,tar there.once they become a ROOFING TRUCK there never the same...lol
01-02-2009, 10:44 PM | #6 |
I know some of you aren't going to believe this, and that's OK, I wouldn't believe it either, but my 2000 Z71 has the factory pads and rotors and it just turned 118K. The pads still have about 1/3 of the life left, but starting back around 100K the rotors started vibrating a little bit and have a slight pulsing during braking now. It's getting time for new pads/rotors.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
01-03-2009, 05:08 PM | #7 |
153k and i have not touched the brakes yet. Still got plenty of pad left 02 silverado 1500 lt a great truck
01-03-2009, 05:31 PM | #8 |
WOW you guys must drive like the Church Lady from Saturday Night Live LOL.I have pulled a lot of dump trailers with this truck, been to Flordia 2 times we worked a couple of hurricanes down there I was still thrilled with 70 k plus.Well good braking to all,,,
01-04-2009, 01:57 PM | #9 |
Be sure to double check the inner pads on the front. There is a recall for failing anti-lock sensors which results in premature wear on the inners.
01-04-2009, 04:20 PM | #10 |
There was a recall, but it only affected vehicles in areas/states where salt was used on the roads. The salt corroded the sensors.
01-04-2009, 08:46 PM | #11 |
It was time to do the rears on my 03 at 86k. I went ahead and did my fronts because I bought cross drilled and slotted rotors all the way around and painted my calipers. No doubt the fronts would have lasted alot longer.
03 ext cab stepside silverado bagged on 20's with some other cool stuff (daily driver) 1970 c10 short step just gettin started on it (project) |
01-06-2009, 12:48 PM | #12 |
Gone Fishing
I have an 06 GMC CC and have a little over 30k and need to change the fronts soon and maybe the rears
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
01-06-2009, 01:36 PM | #13 |
I have a 2002 Silverado with 86,000 miles.Same pads.Still look good and feel good.My truck is a stick shift which might help save the pads while using the gears to slow down instead of the brakes.
01-07-2009, 01:35 PM | #14 |
I also got 118k out of my original fronts. still on the original rears (knockin' on 140,000 ) could have gone longer on the factory fronts but I replaced wheel bearings so figured I would do breaks as well.
Andy... '70 C/10 Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=298553 '71 K/20 Frame-off resto, SOLD!!! http://67-72chevytrucks.com/vboard/c...ct=2399&cat=12 '05 Silverado Z-71, CC SB, Daily Driver |
01-07-2009, 07:56 PM | #15 |
02 2500HD 91,000 and brakes still have 1/2. I also live in a rural area with little or no town driving.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
01-07-2009, 09:03 PM | #16 |
mine are both drivin in the city & burbs where you brake every block.i bet you will not get these kind of replys from da dodge & ford guys ..
01-13-2009, 07:59 AM | #17 |
My 1999 2500 w wheel discs went 140k. I had to replace them, pads, rotors, lines, and MC, after letting it set for a year (less than 600 miles in 16 months). Basically the system just rusted off. The pads still looked good. the parking brake was junk though.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
01-19-2009, 08:26 AM | #18 |
RIP Mr Ron
I have a 99 Chevy 1500 extended cab with 165000+ on it. I replaced the rear brakes at 135000 miles and the front have never been touched. I pull a 16' flat trailer that I haul a D-17 AC with a bush hog or box blade on when not collecting old trucks and race cars. I even pull my 24' enclosed with my 72 nova in it. I use mine hard but I use common sense. I don't wait till I should be stopped to start stopping.
Ron (Mr Round Tuit) Be kinder than necessary, for everyone you meet is fighting some kind of battle TN Message Forum TN Facebook Group SETN Truck Show My Photobucket |
06-01-2010, 05:33 PM | #19 |
I bought my 2003 CCSB 1500hd 4x4 used with 100K on it, and now at 125K I need to replace the rear brakes/rotors. The front pads look to have a little longer to go. I did have to replace the driver's front wheel bearing at about 120K. That was a big pain in the rear to do.
2003 Chevrolet CCSB 4x4 1500HD Mine 2011 Toyota Corolla S Wife's new ride 2002 Pontiac Grand Am SE2 Wrecked/Totaled 2014 1990 Chevrolet 454SS GONE 02/26/11 1991 S10 SCSB GONE 12/24/08 1965 Chevrolet LB GONE 06/06/05 GM for life |
06-01-2010, 08:26 PM | #20 | |
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
06-03-2010, 06:30 PM | #21 |
The LuvShack Garage
We got 202,000 out of the Wife's 99 4wd Trailblazer Factory set.
Out of the 8 pads, it has 4 wheel disc, only 1 got into the metal.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
06-03-2010, 07:38 PM | #22 |
I believe my brother's 99 Silverado went around 120k miles before he had to do 1 single thing to the truck.
You can't go wrong with GM |
06-03-2010, 08:56 PM | #23 |
fronts around 80k and rears at 145k
1972 K20 lwb 2000 Z71 x-cab 1970 ford f100 |
06-04-2010, 12:13 AM | #24 |
Windy Corner of a Dirty Street
110K on a Silverado HD and 100K on a 2004 Tahoe. The pads on both rigs look like new.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
06-04-2010, 12:17 AM | #25 |
Charlie Daniels w/ a Tq Wrench
128k mi on original brakes on my 2500HD, and it has been used for pulling trailers most of its life, and the last 30k miles have been with 37" tires. Last time I had the wheels off to rotate the tires, the pads front and rear looked to have plenty of life left.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
