Just a nother gear head
Re: 2001 suburban starting issues
X2 on the regulator. had the same problem on my 2000 6.0L. An easy check is to pull the vacuum line off the reg and if fuel comes out its no good. beware they are about $100 bucks. the reg is on the left side, above the valve cover right where the fuel lines connect.
2013 HD FLHX 2000 chevy 2500 6.0l 4x4 3dr 2000 harley fxdx 71 Jimmy 4x4- future crawler/ woods rig 71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589 ![]() |
Thanks guys, i'll check it out tonight and see what i can find out.
Would the regulator cause it to idle a little rough and stutter when accelerating from a stop?
Did you check the regulator like previously stated? If no fuel was present in the vacuum port, check the fuel pressure (key-on engine off 55-62 psi). Did you change the fuel filter? Check engine light on?
No fuel was in vacuum port, the check engine did come on today when it started running bad. Autozone scanned it said it was a miss-fire on multiple cylinders. (with new plugs and wires?) I did get a fuel filter, going to install it tomorrow after work.. How do I check fuel pressure on this engine? Also the Autozone employee that scanned it said since the rough idle is throwing the engine off balance that means its an odd number cylinder??? is that correct?
#6 | |
#8 | |
rudy67chevy
