Old 06-04-2010, 01:10 PM   #1
gonzo6869
Cops, ha, catch me if you can!
gonzo6869's Avatar
Brake Light.
I am going to assume the brake light on the instrument panel just indicates that the parking brake is on, I can't imagine that there are sensors for the brake system indicating there is a problem. The reason for me asking this is; I was driving in to work today and noticed the brake light was on (parking brake was off), the brakes work fine, so I am guessing it is just the switch for the parking brake that went bad. If some one can let me know if the light means something more then what I think, I would appreciate it.
Thanks,
Josh.
72 C-10 Stepper
350/TH350
3.73 in the back
Edelbrock intake and Carb
Hooker Comp Headers
275/60R15 on Rallies
gonzo6869 is offline   Reply With Quote
Old 06-04-2010, 01:19 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Brake Light.
Brake light means there is something wrong. Check the fluid level in the MC, check for leaks in the whole system. Though it could be an electrical malfunction.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 06-04-2010, 02:12 PM   #3
gonzo6869
gonzo6869's Avatar
Re: Brake Light.
I will check the fluid level.
72 C-10 Stepper
350/TH350
3.73 in the back
Hooker Comp Headers
Old 06-04-2010, 03:19 PM   #4
Keith Seymore
Keith Seymore's Avatar
Re: Brake Light.
If your truck has a brake proportioning/combination valve: there could be electrical content there. If you have a leak in the front half or back half of the system, it will "shuttle the valve" to close the offending side off - and - turn the light on in the dash.
Because most of the braking is done with the front, conceivably you could close the rear brake system off and not really even notice.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 06-04-2010, 05:07 PM   #5
gonzo6869
gonzo6869's Avatar
Re: Brake Light.
I will give that a look as well.
72 C-10 Stepper
350/TH350
3.73 in the back
Hooker Comp Headers
Old 06-04-2010, 05:20 PM   #6
fixit-p
fixit-p's Avatar
Re: Brake Light.
If the tan wire going to the prop valve is shorted to ground it will also cause the light to come on, a quick test is to disconnect it from the prop valve if light stays on problem is in the wiring if light goes out problem is in the brake system
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 06-04-2010, 05:26 PM   #7
raycow
Re: Brake Light.
On factory dual/split systems, which I think is everything since 1967, there is a switch in the distribution block. This switch will light the brake warning lamp in the event of pressure loss on either side of the system. Unfortunately, it doesn't reset automatically. Disconnect the wire from the switch, and if the lamp goes out, that's where the problem is.
Ray
raycow is offline   Reply With Quote
Old 06-04-2010, 06:37 PM   #8
gonzo6869
gonzo6869's Avatar
Re: Brake Light.
If the problem turns out to be the Proportioning Valve, is it safe to drive it for short distances till I get time to fix it? The last thing I want is to lose my brakes and wreak my truck.
72 C-10 Stepper
350/TH350
3.73 in the back
Hooker Comp Headers
Old 06-04-2010, 06:38 PM   #9
gonzo6869
gonzo6869's Avatar
Re: Brake Light.
Ray
Ray,
Are you talking about the the wire that plugs into the Valve body?
72 C-10 Stepper
350/TH350
3.73 in the back
Hooker Comp Headers
Old 06-04-2010, 06:53 PM   #10
gonzo6869
gonzo6869's Avatar
Re: Brake Light.
I only got this truck about a year ago and I don't know what kind of brake fluid the previous owner might have used, I am guessing DOT 3 is standard for these trucks, am I correct?
72 C-10 Stepper
350/TH350
3.73 in the back
Hooker Comp Headers
Old 06-04-2010, 07:32 PM   #11
Sinister
Between Trucks...
Sinister's Avatar
Re: Brake Light.
DOT 3 brake fluid, IIRC. The wire goes to the proportioning valve which connects to the master cylinder. I would figure this out before you go driving around.
Beat it to fit,
Old 06-05-2010, 12:13 AM   #12
raycow
Re: Brake Light.
Originally Posted by gonzo6869 View Post
Ray,
Yes, that's the switch. Just disconnect the wire and see if the light goes out.
Ray
Old 06-07-2010, 09:26 AM   #13
gonzo6869
gonzo6869's Avatar
Re: Brake Light.
I think I found the problem, after looking in the engine compartment, I noticed brake fluid that had leaked onto my firewall, look at the MC and found that fluid was leaking out of the top from the rear reservoir. I took the cover off to inspect the gasket and noticed some dirt on it as well as on the top part of the MC, I cleaned them, filled up the rear reservoir and no more light.
Just want to thank everyone for the help.
Josh.
72 C-10 Stepper
350/TH350
3.73 in the back
Hooker Comp Headers
Old 06-07-2010, 10:37 AM   #14
Sinister
Between Trucks...
Sinister's Avatar
Re: Brake Light.
Glad you got it sorted out. I would keep an eye on it just to make sure.
Beat it to fit,
Old 06-07-2010, 02:18 PM   #15
gonzo6869
gonzo6869's Avatar
Re: Brake Light.
I will keep an eye on it. One question, would a bad seal on the back reservoir cause the brake light to come on, would that create low pressure for the back brakes? Well I guess thats two questions.
Thanks again,
Josh
72 C-10 Stepper
350/TH350
3.73 in the back
Hooker Comp Headers
Old 06-07-2010, 02:21 PM   #16
Keith Seymore
Re: Brake Light.
Thanks again,
Josh
Low pressure for the back brakes would cause the combination valve to "shuttle" (ie, shift off center) turning on the light.
Hopefully, adding fluid restores the pressure to the rear, and the first "hard" depression of the brake pedal re-centers the combination valve, turning the light back off.
That's how it's supposed to work, anyway -
K
1979-1986
1986 - 2019
Old 06-07-2010, 02:21 PM   #17
Sinister
Between Trucks...
Sinister's Avatar
Re: Brake Light.
If the seal was bad and it was leaking, yes.
Beat it to fit,
Old 06-07-2010, 03:13 PM   #18
gonzo6869
gonzo6869's Avatar
Re: Brake Light.
That is exactly what happened, filled the fluid cleaned the gasket and when I came to a hard stop I felt a little click or something on the brake pedal and the light went off. I am glad it was an easy fix; I was getting ready to get a new Proportioning Valve and heard that it can be a pain to get the new one working properly.
Josh
72 C-10 Stepper
350/TH350
3.73 in the back
Hooker Comp Headers
Old 06-07-2010, 03:40 PM   #19
red71c10
The Red Menace
red71c10's Avatar
Re: Brake Light.
Thanks,
Josh.
Going back to your original post, I don't think the dash light serves two purposes. It doesn't indicate when the parking brake is on, it only indicates trouble with the braking system.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline   Reply With Quote
Old 06-08-2010, 10:15 AM   #20
Mike Quillici
Re: Brake Light.
I am experiencing a similar problem, except my brake light on the dash is flashing. It's never done this before, and everything appears to be okay. I checked the brake fluid, and the truck stops fine. The weird thing is that it also flashes when the ignition is on, but the truck is off. . .
1972 Chevy C-10 ~ 188,000 miles give or take
Mike Quillici is offline   Reply With Quote
Old 06-08-2010, 01:10 PM   #21
mrein3
mrein3's Avatar
Re: Brake Light.
Isn't there a brake light switch on the parking brake? Or am I thinking of my Chevelles?
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 06-08-2010, 03:41 PM   #22
gonzo6869
gonzo6869's Avatar
Re: Brake Light.
I think your right, I thought it came on with the parking brake, but now that the problem is fixed the light dose not come on with the parking brake engaged.
72 C-10 Stepper
350/TH350
3.73 in the back
Hooker Comp Headers
Old 06-08-2010, 03:44 PM   #23
Mike Quillici
Re: Brake Light.
Does anyone have any thoughts about why the light would flash??
Old 06-08-2010, 03:48 PM   #24
gonzo6869
gonzo6869's Avatar
Re: Brake Light.
Dose it flash all the time?
I would not know why it would flash, but try unplugging the wire on the valve body and see if you still have the problem, if you do its electrical and not mechanical.
72 C-10 Stepper
350/TH350
3.73 in the back
Hooker Comp Headers
Old 06-08-2010, 03:51 PM   #25
fixit-p
fixit-p's Avatar
Re: Brake Light.
Do the test in post #6 if the light doesn't go out or stop flashing then that means the tan wire is shorting to ground. the tan wire also goes to the ignition switch to illuminate the light while cranking to serve as a bulb check.
brake, light
