Old 06-04-2010, 07:41 PM   #1
EZTHERE
Re: GM factory mistake, 350 Vet motor in my 72.
Carb is a Rochester "4MV" Quadra-Jet 4-barrel carburetor. the motor is painted orange.
At the moment im at work, so I dont now what the numbers are. Did the 72 Jimmy's come with 4bbls?
EZTHERE is offline   Reply With Quote
Old 06-04-2010, 08:28 PM   #2
Critter
Future TOTM Winner
Critter's Avatar
Originally Posted by EZTHERE View Post
Has anyone ever heard of that before??
Yes we have "heard" of it lots of times, but so far they have all been inaccurate or an engine that was put in by a previous owner etc, but never actually installed by GM. Not trying to burst your bubble, but a whole mess of people on here joke about the "rare corvette option" blazer/jimmy/truck. Just warning you.
On a 350, yes, the 4bbl Q-Jet was very common.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 06-04-2010, 08:58 PM   #3
Jtrux
I'm a poor spectator
Jtrux's Avatar
Not just common, but mandatory. I think the only 2bbl carbs were put on 307's. And i'd say that it's probably possible for the dealer to swap motors at the owners request and dime but not too likely. My dad has a 77 chevy lwb 4x4 that just plain hauls a$$. A peak under the hood revels bone stock engine, stock carb, intake, manifolds, everything. The guy he bought it from insisted it was the original stock engine, I just couldn't believe it so a little poking around under the hood and you can tell someone has been into it, it may just be a cam install but it doesn't take much to pep one of these motors up a little. Stock cams sucked. So what i'm saying is that it's very possible for someone to crack into it and change the cam, especially if the paint looks pretty fresh or if just the water pump and timing cover are painted. Those are dead giveaways.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 06-05-2010, 12:54 AM   #4
EZTHERE
ok these are the numbers ive gotten.
RT head. 3973487X date K 3 1.
LT head. 3973487x date k 4 1.
Manifold 6263751
Rochester Q jet 17054927
Front pad. V11 I 6 TDG
the manifold gives it away. Its a 200hp 350, I can reach the block number.
I could use some help with the engine number on the front pad. thanks
Old 06-05-2010, 01:02 AM   #5
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Maybe it's one of those rare Corvette optioned trucks.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 06-05-2010, 08:46 AM   #6
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
heheheh
Tom Vogel is offline   Reply With Quote
Old 06-05-2010, 12:59 PM   #7
pumpkin
pumpkin's Avatar
Small block chev is a small block chev. If its in a corvett, its a corvett engine, if its in a truck, its a truck small block. Most vetted just came with regular old small blocks, maybee a bit better cam, its not till you get into things like an LT1. 2.02 heads, SOLID lifter cams, forged cranks, stronger rods and such. Having a corvette 350 means nothing. I have a motorhome sbc 400 in my blazer that will wax a vette 350. Get over the Corvette option. Gm did on ocasion put hotter than called for 350's in vehicles, by mistake, at change overs, or when thay ran out of what was called for. I have a buddy that worked at a GM dealer back when our trucks were new, and he found a few of these. He tells me that the owners of these vehicles, would come in complaining that the engine didn't idle as smooth as his neighbors. So under warranty the would change out the Corvette camshaft for the smaller cam.
pumpkin is offline   Reply With Quote
