not enough hours in the day
Fan shroud sizes?
I have a new fan shroud that came with some parts I bought that I need to know the application. It is 5" deep and offset somewhat. The opening is 6" from the left side and 4 1/4" from the right side. Does anyone have dimensions for the different shrouds?
Hollister Road Co.
Re: Fan shroud sizes?
It sounds like it was for an electric fan. Some times the fan needs to be off set to clear the water pump
Here's a photo
Bump, anyone know what application this would be for?
Not to revive an old thread, but i too have one of these shrouds I got in a pile of parts. I wonder if it is a big block shroud. bolt holes are 28-3/8" oc on top and 18" oc on bottom.
Cruzin
Looks deep like a 4 wheel drive shroud,here is a pic of my shroud (aftermarket) but it's for a 67-72 4x4 (deeper) since my trucks small block is mounted in the orginal 6cly. location i had to use the 4x4 shroud. Maybe this helps some.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
