#27 |
Insert Title Here
Re: sittin lower!
sits perfect, i wouldnt change it
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
#28 |
.. !WAR FEDOR! ..
Re: sittin lower!
youre right, thats what i think most people that go that route feel like, if i do switch out my springs ill be close though, 2.5'' spindle and a 2''spring
"san diego chargers #1" |
#29 |
Insert Title Here
Re: sittin lower!
They have these, but they dont have the slots cut in them like some trucks have
http://wheelvintiques.myshopify.com/...lver-42-series
#30 |
.. !WAR FEDOR! ..
Re: sittin lower!
they have the truck wheels on summit, they are the 42 series, my dad ordered them.
http://www.summitracing.com/parts/WVI-42-580504/
#31 |
At the body shop.
Re: sittin lower!
Looks Sweet. Id like to see it when you flip the back too.
" That didnt make it any newer " " Dont antique the equipment " |
#32 | |
Badass
Re: sittin lower!
http://www.summitracing.com/parts/WVI-42-5005042/
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90
#33 |
Re: sittin lower!
What's the problem with 3" springs, is it ride quality?
#34 |
.. !WAR FEDOR! ..
Re: sittin lower!
The ride quality is fine, but combined with my spindles, its just a bit much for a DD around here, my A arms scrape at every speed bump.
#36 |
.. !WAR FEDOR! ..
Re: sittin lower!
this low
"san diego chargers #1" Last edited by joe1982; 06-06-2010 at 07:07 PM. |
#37 |
Re: sittin lower!
looking sick man. i would let it ride. thanks for your service btw.
#38 |
Re: sittin lower!
My truck sits the same way. You just have to dodge or slow down on speed bumps. Watch out for man hole covers.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
#39 |
Re: sittin lower!
Looks Great.. Nice Job
Justin |
#40 |
Re: sittin lower!
looks tits bro! I would just drop the back 1in lower and go from there
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
#41 |
.. !WAR FEDOR! ..
Re: sittin lower!
Thanks for the kind words fellas, I'm on duty today, so tomorrow I'm going to try and leave work to finish up the rear. Ill post some pics
#42 |
Re: sittin lower!
#43 |
.. !WAR FEDOR! ..
Re: sittin lower!
I have one, just haven't thrown it in yet.
#44 |
Re: sittin lower!
That can help some with your scraping some if the sway bar is on.
Without it if you hit a bump offcenter at all the truck will tend to rock side side more and might cause more suspension compression on one side and then you bottom the A-arm of frame out. Now if your just that low your going to scape if you go straight over a speedbump then its the ole go over them at an angle routine. Have had to do that alot myself on my SCCA solo two autocross street driver. |
#45 |
.. !WAR FEDOR! ..
Re: sittin lower!
lowered the rear today, total of an inch and some change. im sitting at about a 5ish 7ish. i only have about 3inches of clearance out back!! so i am getting on summit and getting me a notch kit righht meow!
#46 |
Kvn1011
Re: sittin lower!
LQQKin good!!
#47 |
box junkie !!
Re: sittin lower!
very nice !!!!! i think they should just make the roads nicer haha problem solved !! perfect stance in my honest opinion. wonder how a 30" tall drag radial would tuck in the back at that ride height? 295/65R15 MT DR 29.6" tall , 12.4" section width
- 500mg of crazy a day ...... will keep the straight jacket away !!! ![]() :burno
#48 |
box junkie !!
Re: sittin lower!
#49 |
Re: sittin lower!
looks great!
#50 |
Truck Junkie
![]() Join Date: Aug 2008
Re: sittin lower!
Joe1982 truck for truck, i believe you have one of the best sitting truck on this board without the high dollar alloy wheels and exotic suspensions, don't get me wrong they are all sharp rides. So tell me what would you do different to get this look? I recall you talking about bottoming out is this still a problem or just something you have to deal with? how did you drop the rear? All in all this is one sharp truck! Where did you get the goodyear tires in a 295?
| Bookmarks |
