03-27-2010, 11:06 PM | #1 |
4l80e swap?
putting a 4l80e in my truck had 350 turbo what cross member do i need
03-28-2010, 12:34 AM | #2 |
Active Member
Re: 4l80e swap?
Stock cross member will work, it needs to be measured to the length of the new tranny, then re-drill the frame for that position. You will also need a 4L80e mount and bit of fabrication to have it fit the stock x-member.
I'm doing the swap from a th400 to a 4l85e super-matic the end of next week, I'll get some pictures up to show off my "electrician trying to play mechanic" skills, you can learn from my mistakes...
"The Great State of Florida" |
03-28-2010, 10:39 AM | #3 |
Re: 4l80e swap?
well i don't mind buying aftermarket cross member would in fact rather do so then trying to mod old one and having it look like sh**.cause im no fabricator
03-28-2010, 11:57 AM | #4 |
Active Member
Re: 4l80e swap?
There are a few aftermarket cross members out there ranging in price from $70.00 to $270.00 they are all basically the same part give or take powder coating, painted or raw. Thing is all those that I have seen are advertised as being for a TH350, TH400 or 700-R4 none of them are specific for a 4l80e, or 4l60e.
Also the tranny mount itself is a different piece for a TH's and a 4L's, I think one is two bolts to the tranny and the other one bolt to the tranny? Anyone else out there having done this conversion with an aftermarket x member what did you use and what was the solution?
03-28-2010, 05:16 PM | #5 |
Re: 4l80e swap?
I am curious about how the speedo is done.
03-28-2010, 06:11 PM | #6 |
Active Member
Re: 4l80e swap?
I pined over this as well going from a mechanical to an electric speedometer. The options I found were: New tranny tail shaft housing $400 then adding a drive gear, sleeve and driven gear, sleeve retainer, and bolt added another $250, So $650 total-ly insane Cable X makes an electronic to mechanical tachographs that can also do the trick for $350 A specially machined output shaft that allows you to use a stock TH400 gear in a 4l80e A few hundred bucks for that also However I believe that all of these options require a Electronic Ratio Adapter to adjust for tire size or gear swap another $170. Needless to say the price is steep for something that should be so simple, then it hit me, two birds with one stone for about $200... And the gauges are an upgrade that I have been wanting to do for some time now and this speedo just plugs into the 4l85e harness, simple is as simple does...
03-28-2010, 07:44 PM | #7 |
Factory Strippers Rule!
Re: 4l80e swap?
Not trying to hijack, but will a 4L80E fit a low hump cab? I need to know... and I hope the answer is yes.
"Feast your eyes on a feast of smoke." 67 Chevy Short Fleet PLAN: LQ9, 4L60, D60 Looking for School Bus Gauges - Help me out! |
03-28-2010, 09:05 PM | #8 |
Re: 4l80e swap?
never thought about that but don't see why it wouldn't
03-28-2010, 10:04 PM | #9 |
Re: 4l80e swap?
Mine fit fine. And you don't need to modify the crossmember at all, just move it back and drill new holes in the frame, super easy. You also don't need the 4l80 mount, use the 350 turbo one it will bolt directly to the trans, you just need to use the metric bolts from the 4l80e
03-28-2010, 10:26 PM | #10 | |
Re: 4l80e swap?
03-28-2010, 10:37 PM | #11 |
Active Member
Re: 4l80e swap?
Thanks for the info nova...
03-28-2010, 10:58 PM | #12 |
Re: 4l80e swap?
How do you "control" it?
Is there a "stand alone" computer kit for them?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
03-28-2010, 11:03 PM | #13 |
Re: 4l80e swap?
yea there is thats the downfall its 1100 dollars but i would have that much in a 700r4 that wouldn't hold the power i want
03-28-2010, 11:17 PM | #14 |
Re: 4l80e swap?
Wow, that is pricey!!!
It's only money though, right?
03-29-2010, 10:20 PM | #15 |
Re: 4l80e swap?
is there not another option for controlling it other than $1100
'71 C20 350 TH400 2004 Subaru STi Excuses are bridges to nothingness. Last edited by cplkillian; 03-29-2010 at 10:20 PM. |
03-29-2010, 10:43 PM | #16 |
Re: 4l80e swap?
I have heard of guys using computers out of 90-93 chevy diesel pickups that had mech injection and 4l80
03-30-2010, 12:08 AM | #17 | |
I have a radical idea!
Re: 4l80e swap?
packers05 is correct. 91 - 93 diesel trucks, 6.2 N/A and 6.5TD, had a stand alone ECM just for the transmission since the engine was no computer controlled. In '94, the engines got computers and it was integrated.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
03-30-2010, 01:18 AM | #18 |
Re: 4l80e swap?
I checked car-part.com and they have plentey
91 - 93 diesel trucks Trans only computor from $45 to $100
1950 Chevy 1500 1961 C-10 1969 C-10 1971 Chevelle 2008 Dodge HD3500 Tow Rig |
03-30-2010, 09:48 AM | #19 |
Re: 4l80e swap?
that seems a whole lot more reasonable
'71 C20 350 TH400 2004 Subaru STi Excuses are bridges to nothingness. |
03-30-2010, 04:34 PM | #20 |
Re: 4l80e swap?
my stock X-member is used along with no drilling on frame. I did use the 4l80 trans mount b/c it is slightly offset and works better.
You will need a trans controller, and it's $$. I am using an Abbot Cable X unit to run my stock speedo from the PCM. (I can ship those for $300) I have a low hump cab and plenty of room.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
03-30-2010, 08:17 PM | #21 |
Re: 4l80e swap?
I wondered about aftermarket speedos made for the electronic transmissions.That`s what I`ll do.My 4L80E is out of my`91 Diesel 3/4t Suburban.If I don`t resurrect that the trans goes in my`72.
06-05-2010, 10:23 PM | #22 |
Re: 4l80e swap?
ok so i just found out mine is a 93 so what do i need for this stand alone computer does anyone have pictures or info
