Old 06-04-2010, 05:25 PM   #1
crapy67
White wall terror
crapy67's Avatar
How low can I go
I want to drop my 71 long bed as low as I can go with just coils and I dont want to notch the frame or get drop spindles, but I want to be able to get an aligment and I dont want the frame to smack the axle. So what do you guys think. Thanks... Mark
crapy67 is offline   Reply With Quote
Old 06-04-2010, 05:53 PM   #2
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: How low can I go
I think you can get away with a 3/5 drop, but you would need a new panhard bar and possibly need a C-notch.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 06-04-2010, 07:33 PM   #3
big_al_71
big_al_71's Avatar
4/6 all day long no notch needed, you will have to get an adjustable panhard bar...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 06-05-2010, 12:28 AM   #4
Jacfourteen
I always heard that 5" or more in back and you need a notch, yours never hits the frame? Did you have to get rid of the bumpstop?
Old 06-05-2010, 12:53 AM   #5
crapy67
White wall terror
crapy67's Avatar
Yo Big Al, is that what your rig is running on? If so whats the manufacture on the springs? I need details please. Thanks... Mark
Old 06-05-2010, 12:54 AM   #6
T/C
T/C's Avatar
Mine sits about like his (Not sure on exact drop) But it hits frame if i have anything in the back or if i hit a really big bump..
T/C is offline   Reply With Quote
Old 06-05-2010, 01:03 AM   #7
crapy67
White wall terror
crapy67's Avatar
so whats your set up T/C
Old 06-05-2010, 02:12 AM   #8
chevyblazer
chevyblazer's Avatar
hy coils in front like 4" in the back colis to same size or some blocks and chenge track bar
cucharitas customs
chevyblazer is offline   Reply With Quote
Old 06-05-2010, 07:08 AM   #9
big_al_71
big_al_71's Avatar
The bumpstop is gone and I put a small urethane one in there just in case it ever hits it wont be metal to metal..I have carried some furnitureand equipment in there and dont remember it ever bottoming out then again here in South Florida the roads are nearly perfect I dont know how it would ride on some rough roads.
Mark, I went with the kit from ECE "Early classics" 4/6....
Old 06-05-2010, 08:26 AM   #10
lolife99
67-72 parts collector,…
lolife99's Avatar
3/5 is it with just coils.
No notch needed.
The 4/6 or lower will require drop spindles up front.
Keith
Convert to disc brakes.
Old 06-05-2010, 09:31 AM   #11
T/C
T/C's Avatar
Not sure it was done before i got the truck... I will be going lower though in the far future for now i am just going to re do the front cause i think all they did was heat the springs and i want it to ride a little better.. C Notch and bags wil come some day..
Old 06-05-2010, 10:57 AM   #12
bigsnookmaster
bigsnookmaster's Avatar
I would do at least drop spindles in the front so you can keep some front end geometry in it, and still have some travel left in it. I just did the drop spindles from Early Classic, and they were an easy bolt in,with no problems. Very quality pieces! Good luck
bigsnookmaster is offline   Reply With Quote
Old 06-06-2010, 09:26 AM   #13
crapy67
White wall terror
crapy67's Avatar
Thanks for the replys. I never had this much trouble trying to figure out what parts to order before...Mark
