It is time for me to put my 63 c10 swb stepside back together...it is is currently in many pieces!!! Here are my questions: 1) I need to get the cab weather seals and want to buy a COMPLETE kit...which ones would you all recommend? 2) Need to replace the sheet metal fasteners, nuts and bolts...again what are your recommendations? and 3) There are lots of seals around the engine compartment (thanks for the expoded view aerotruk63)...where is the best place to pick these up? Any input would be greatly appreciated as this is a first...even if you know what not to buy I would really like your input.
Re: Time to put it together...best choices????
I have had good luck with these outfits:
www.classicparts.com www.lmctruck.com www.oldchevytruck.com www.bowtiebits.com www.truckandcarshop.com www.brothers.com |
Thanks Tony! I've seen you recommend Totally Stainless for fasteners in the past as well...still like them?I have also seen some talk of using seam sealler between some panel (Inner and outer fender) do you or have you done this? Is it a good idea?
