Old 06-07-2010, 09:31 AM   #1
ljackson
ljackson's Avatar
6 to 5 lug rear axle (Weld and redrill)?
Has anyone had a machine shop weld and redrill their axles?
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 06-07-2010, 09:47 AM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 6 to 5 lug rear axle (Weld and redrill)?
Here's an earlier thread on the topic:
http://67-72chevytrucks.com/vboard/s...ight=rear+axle
And here's a tip - when redrilling, one or more of the existing holes need to be plugged. Rather than puddle welding the hole, the guy that did mine sliced up an axle stud keeping only the splined portion. That was pressed into the hole and tacked in place, avoiding excessive welding that could warp the flange.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 06-07-2010, 12:54 PM   #3
jason65
Registerd User
jason65's Avatar
I used a kit like this to convert mine. http://www.classicperform.com/Store/.../6369RAC-5.htm
jason65 is offline   Reply With Quote
Old 06-07-2010, 02:24 PM   #4
Hickup pickup
Hickup pickup's Avatar
I had Key Engineering (tom yancer racecars) do mine, It is necessary to weld at least one, but two is better, holes also I had them turn down the center of the hub to match the 5 lug hub centric diameter leaving a ridge to center the 6 lug drum which was also re drilled but not necessary to weld. He charged me $125.00 for the whole job or $35 each for just the axles
2-20, 2-21 whatever it takes!
Hickup pickup is offline   Reply With Quote
Old 06-07-2010, 06:47 PM   #5
SCOTI
SCOTI's Avatar
That how I had some 6-lug axles/drums done. I wanted the GM car pattern (5x4.75).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-07-2010, 11:54 PM   #6
tapeworm
fan of "Butters" Stotch
tapeworm's Avatar
I've heard Moser does a good job as well. There is alot of discussion about this on the HAMB as well
64 shortbox fleetside
replacing rusty junk with more junk, and one day to become a real truck again
tapeworm is offline   Reply With Quote
Old 06-08-2010, 12:19 AM   #7
SCOTI
SCOTI's Avatar
I did mine back in the late 80's/early 90's. If I did it again today, I'd go aftermarket (moser).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-08-2010, 01:04 AM   #8
Captainfab
60-66 Nut
I would guggest first making sure that the wheel bearing surfaces on your axles are in good condition before putting any money into them. Check with your local welding/machine shops to see what they will charge to do the work. Then compare those figures with what a set of aftermarket conversion axles will cost. As Jason posted, CPP sells them as well as ECE and Summit Racing. If your truck is a '63 or '64 you will need to replace the spider gears if you go with the aftermarket axles. That is another cost to factor into the swap.
Old 06-09-2010, 01:04 AM   #9
tapeworm
tapeworm's Avatar
[QUOTE=Captainfab;4020130]As Jason posted, CPP sells them as well as ECE and Summit Racing. If your truck is a '63 or '64 you will need to QUOTE]
Good to know that
What spider gears need to be used?
Old 06-09-2010, 01:21 AM   #10
Captainfab
60-66 Nut
The '63 & '64 rear differentials had 17 spline side spiders. The '65 and up had 30 spline side spiders. The conversion axles are for 30 spline side spiders. CPP and ECE sell replacement side spiders also. You might check with some of the differential parts suppliers, and compare pricing.
[quote=tapeworm;4022007]
Good to know that
Old 06-09-2010, 07:21 PM   #11
ljackson
ljackson's Avatar
Thanks to all for the info. markeb01, I searched several ways and did not find anything. Thanks for the link. The info provided here is very good. I am going to call my machine shop guy. I'm building a '64 with my son. We are on a pretty tight budget.
Eugene
Old 06-09-2010, 09:28 PM   #12
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Just bookmarking as my own question was answered in the linked thread. Thanks for the info guys.
fryer1979 is offline   Reply With Quote
6 to 5 lug, redrill, weld
