Old 06-08-2010, 02:18 PM   #1
golfgooroo
Frame identification
I'm in the process of tearing down a '59 Apache body on what I think is a '77 chevy frame. Is there a particular place where the frame might be stamped so I can confirm which frame is on the truck. I'm looking into the Paul Horton's IFS and for other obvious reasons I want to know exactly what frame I have. I just got the cab off this weekend, so the real fun begins. I'm going to really enjoy getting down to the bare frame and starting there!
golfgooroo is offline   Reply With Quote
Old 06-08-2010, 02:23 PM   #2
blackdiesel
blackdiesel's Avatar
Re: Frame identification
welcome to the site. If your going to put an aftermarket IFS, I would start with the right frame.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 06-08-2010, 04:08 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
Post a picture.
Old 06-09-2010, 07:24 PM   #4
mr48chev
mr48chev's Avatar
I agree with that 100%, I don't see any advantage to trying to cobble a later frame under a truck only to swap suspensions later. The idea of running a later frame is usually to get the later suspension with it. Other than that there is no advantage.
Old 06-09-2010, 11:28 PM   #5
Fred T
Cantankerous Geezer
Fred T's Avatar
If it is a post-72 frame part of the VIN should be stamped on the top of the frame, drivers' side, around the front axle area.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 06-10-2010, 07:53 AM   #6
golfgooroo
Thanks for the help. The fact of the matter is that the frame was already swapped when I picked up the truck. The suspension currently on the truck may be an upgrade to the '59 but it's still thirty years old and needs an update. I'll post a pic when I get back home this weekend. Thanks again!
Old 06-10-2010, 05:31 PM   #7
golfgooroo
here are some pics of the frame. thanks for the help so far. I'm finally finding time to work on the truck, so we should see some decent progress this summer.
Old 06-10-2010, 06:24 PM   #8
Steve@OldSub.com
Cancer Survivor in the making.
Steve@OldSub.com's Avatar
Its not a '77, the long trailing arm rear suspension was only used through 1972. I see front coil springs which mean '63 or later. The power steering box appears to be a factory mounting, which does narrow the frame to later in the '63 to '72 range but I'm not sure how late.
I can't see the front brakes. If they are disk and we can assume this is an unmodified frame, its a '71 to '72.
So not definitive, but that is what I see.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron.
Steve@OldSub.com
OldSub.com . MaxwellGarage.com . OldGasTowRigs.com
Steve@OldSub.com is offline   Reply With Quote
Old 06-10-2010, 09:48 PM   #9
55dude
55dude's Avatar
looks like the one i have under my 59' and with the notch for the p.s. it looks to be 67'-70'. can't see any calipers so not 71'-72' 6 or 5 lug? gas tank looks like add on. a look at the e-brake cable system may help as they changed from middle of truck (hand set) to left side being set by foot! more pic's will help. should be vin# on top of frame.
55dude is offline   Reply With Quote
Old 06-11-2010, 10:27 AM   #10
golfgooroo
I'll definitely try to get the VIN# off the frame when I get home. Just goes to show what the previous owner knew about the truck as well. Once I know which frame, it should be off to the races and the beginning of a good build!
Old 06-11-2010, 01:09 PM   #11
Steve@OldSub.com
As 55Dude suggested count the lugs. Verify his assessment that it has drum brakes.
Those details would narrow the range quite a bit.
Steve@OldSub.com
Old 06-13-2010, 04:24 PM   #12
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
I'd say since it does have the power steering from the factory it would have to be '68 or newer. '67 didn't have the indent in the frame for the steering box.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 06-13-2010, 07:45 PM   #13
dwcsr
Hollister Road Co.
dwcsr's Avatar
Just my opinion but I would work with that frame. Just clean it up and replace the worn suspension parts. The rear trailing arm suspension makes for a real nice ride and is easily bagged if you decide to go that route. 67-72 frames are ok for this swap. Do a disk conversion on the front if its not already disc. Moving to a Paul Horton or any MII on that frame is a step backwards. Its putting a car IFS under a truck frame.
Old 11-05-2014, 09:52 AM   #14
golfgooroo
This truck has been sitting way TOO long! Finally have the time and money to get this into a roller. From the frame talked about above, I've found the following up by the engine bay but can't find any reference to it as a VIN, etc. Any help?
9S844120
Old 11-05-2014, 01:49 PM   #15
Keith Seymore
Keith Seymore's Avatar
My expertise is with squarebodies, but based on what you have posted my guess would be:
9 = 1969
S = St Louis assembly plant
844120 = sequential portion of VIN
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-05-2014, 07:09 PM   #16
mr48chev
mr48chev's Avatar
A 69 Chassis (if nothing's been changed) would have six lug wheels and drum brakes all around.
One has to ask, what do you want the truck to be and do when it is finished?
If it's bagging it to drop it or lay frame there are a pot load of bag kits for that chassis and suspension that let you do that in short order. A lot of guys copy that rear suspension to bag their trucks and a lot of cars.
It's also fairly easy to upgrade the brakes if that is one of the things on the list.
I don't mind seeing a guy spend money on his rig if he accomplishes something but spending money to make changes were changes may not be needed isn't really prudent or possibly wise. You can buy every wear part of the front suspension and steering at your favorite local parts house for that setup and not have to go to specialty vendors for (rare) parts. Several vendors sell upgrade pieces and bags or lowering springs.
Now, what's the whole plan for the truck and what are the driving and use plans when it's done?
My ongoing truck projects:
