GM Addicted
i really want to bag my truck. Id be happy to get a dropmember from PB built but cant afford that was thinking of using an upper plate and a bucket to put in my stock a-arms how low will it actually go? and also ive never really dealt with bags before so what all would i need to make it work? Also the rear would i be able to do a flip kit with some leafs removed and use a bag between the frame and axle just to get it to ride height? Any help would be greatly appreciated.
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
Re: Square bodies bagged with stock a-arms
Ive got stock a-arms and on 22 inch rimz it and the lower arms are on the ground, saven up money for drop member (almost there)
Holy smokes. That k5 has a bunch of lift.
Ok back to the subject... My 68 burb will put the lca's 1 inch from the ground. It has factory arms up front.
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
Happy to be here
![]() Join Date: Mar 2000
If you go with a 3" dropped spindle, plates and stock arms, you can lay the control arms. You will need to pull the inner fenders, but it will lay hard on the arms. You can't get any lower with out a raised or sectioned crossmember, unless you Z or body drop.
GM Addicted
Bagged k5 what do you have in the rear thing lifts up like a coca-roach ahaha. Also what bags up front. New to this bagging stuff can some one explain the hole set up to me ahaha
Active Member
The CPP tubular arms are designed for this type of install. The CPP arms will allow the crossmember to hit the ground, NOT the arm. The extra ground clearance can make for a much improved ride.
Danny Nix CPP |
GM Addicted
which CPP arms tubulars??
Active Member
#9 | |
86 C10
1986 C10 2001 chevy silverado purchased 8-29-09 sold 2004 silverado purchased 8-27-10 sold ![]() |
GM Addicted
Little expensive for my blood right now ahhaha.
low n' slo
![]() Join Date: Mar 2009
lol
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
Here is my 86 with factory control arms they do hit when on 22's but the 24's wont let them hit unless i cut out some of the fire wall or low pro tires
2009 dodge hemi custom paint 86 lwb bagged layin frame 73 2 door nova 54 bel air |
67-72 parts collector,…
![]() Join Date: Nov 2002
Really clean longbed!
#15 |
GM Addicted
Whats everybody running in the rear. Would help to know also.
#16 |
my rear is two link set up ekstinsive here in houston sells its made to lay out on 22's comes with every thing needed
#17 |
Thanx always liked long beds better just a look they have layed out
#18 |
hope these pics help u,sorry so dirty havnt had time to wash under truck today,if u need bettr pics ill send some with wheels off
#19 |
GM Addicted
the top of the bag is mounted on an upper plate? and in rear a 4 link or what?
#20 |
GM Addicted
How much there kit run?
#21 |
https://www.ekstensive.com/store/pro...ca6abf84a884bc
not really sure how to post a link but thats it if it works if not just go to www.ekstensive.com its 650 dollars and comes with every thing needed other then shocks
#22 |
#23 |
I had a kit like that on my '04 and it worked fine (little pricey for a 2 link though). The notch dropped right over the frame like its intended, so you just weld up the outside edges then cut the middle out. Only problem mine had was that the shock tabs on the bars were not at the same angle as the ones on the bridge so I had to do some tweaking to get the shocks bolted up.
#24 |
GM Addicted
the kit for the rear sounds good any one have any others that arent way pricey??
#25 |
You can get a triangulated 4 link kit from Suicide Doors pretty cheap. That is what I have on my '86
