Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 06-08-2010, 11:59 AM   #1
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Timing Advance.
I got a 92 with the 2.5 Iron duke. I was driving home last week and my truck started to sputter like it was out of fuel. I had 1/4 gas left. I got pulled over after I lost power and it just shut off on me. After looking under the hood everything looked alright. so I started it back up. It was idleing fine. Put it in gear start to drive about 50' it starts to sputter again. I've been having a hard time starting it, but it would run good. If I got on it I could smell fuel.
Anyways. I got the truck back to my friends and pulled the coil off since I thought that was the problem. Took it to autozone and tested it, and it was out of the ohm range. So I got everything to do a tune up. I pulled the plugs and they were white. I was using bosch platinum singles. The cap the contacts on the inside were also white. Ok got it runing lastnight, and checked the timeing and it's set at 35* advanced. I'm wondering if this is what it's supposed to be set at. I was reading in the haynes book that the timing being set too much advanced would casue the plugs to turn white.
I'm installing a tach to see what I'm idealing at because it sounds a little high to me.
What should my timing be set at?
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 06-08-2010, 01:06 PM   #2
Tink
Tink's Avatar
Re: Timing Advance.
Timing should be 8 BTDC on these...
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 06-09-2010, 06:59 AM   #3
68C15
blood type; Retumbo
68C15's Avatar
Re: Timing Advance.
you also need to check the timing with ECM command removed. follow the procedure on the underhood sticker.
68C15 is offline   Reply With Quote
