Old 10-06-2009, 07:01 AM   #26
Scott52
Scott52's Avatar
Re: new guy with a 52
yes 3 bolts in the toeboard, i was just checking because the inner fender wasn't bolted and i wasnt sure if there was a bracket or not
Scott52 is offline   Reply With Quote
Old 03-13-2010, 06:42 PM   #27
Scott52
Scott52's Avatar
well i havn't had time to work on the truck untill now, made some progress, got the front clip in
Old 03-13-2010, 06:47 PM   #28
Scott52
Scott52's Avatar
here are some pictures so far, next will be putting in the 9", i'm going to use a camaro style spring probably with a 6 3/8 arch rated at 150lbs
Old 03-13-2010, 07:05 PM   #29
thelonerife
thelonerife's Avatar
that looks gooooood!
thelonerife is offline   Reply With Quote
Old 03-14-2010, 09:46 AM   #30
53GMC
53GMC's Avatar
Great work!!!
1953 GMC/S 10 Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=357365
53GMC is offline   Reply With Quote
Old 03-15-2010, 09:55 PM   #31
Scott52
Scott52's Avatar
here's how the front rims and tire's worked out, the tires are 195/75/r15, i have lots of clearance betwwen the tire and fender when the wheels are turned
i ordered a set of rear leaf springs from Landrum, chrysler style with a 5" arch and a spring rating of 150lbs and the front spring perchs and the pads to mount the 9", so thats next on the agenda
Old 03-15-2010, 11:24 PM   #32
ratty 46
Oh ..... I like where this is going ......
Ratty 46
ratty 46 is offline   Reply With Quote
Old 03-16-2010, 01:45 AM   #33
tobins 52 gmc
tobins 52 gmc
yes very nice start ,looking good .
tobins 52 gmc is offline   Reply With Quote
Old 04-10-2010, 06:54 PM   #34
Scott52
Scott52's Avatar
well i had some more time to work on the truck. i've started to hang the 9", i used Landrum chrysler style asphalt late model springs with a 5.5 arch rated at 150lbs. i moved the front spring perchs to the outside of the frame to get the truck lower, have to gusset the perchs yet. i'm just waiting for my afco aluminum shackles to come to in to get the rear shackle mount made and figure the shackle angle and length i want to use
Old 04-11-2010, 03:11 PM   #35
chev3600
chev3600's Avatar
I cant wait for the rear shackle mount! good work.
plenty of pics, please... I might have to borrow your ideas!
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 04-11-2010, 08:13 PM   #36
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
What clip are you using? The install looks great. I sure do wish that I would have kept my original frame when I see such work as your's. Keep the updates and pix comin'
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
1951 Chevy 2 ton flat bed
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
2008 Chevy Silverado short box 4x4
nickp51chevy is offline   Reply With Quote
Old 04-11-2010, 08:56 PM   #37
Scott52
Scott52's Avatar
the clip is from a 79 camaro, its a leftover from the old asphalt challanger days, had to use a camaro clip then everything back was a tube chassis
Old 05-08-2010, 04:51 PM   #38
Scott52
Scott52's Avatar
i got a chance to do some more work on the truck
well i wound up moving the springs to the inside of the frame, we set the box on and the tire worked out nice in the fender
Old 05-08-2010, 05:06 PM   #39
Scott52
Scott52's Avatar
here's a shot of the box on
we put the hood on to check how the sheet metal is gonna fit, the hood springs are holding the back of the hood up so i will have to figure out something, we have the hinges dropped down as far as they will go, i will be looking for a better hood, someone has done some welding down the centre and the hood is spread where it meets the cowl
Old 06-09-2010, 06:19 PM   #40
tobins 52 gmc
tobins 52 gmc
Hi scott ,haven`t seen much on your build lately hope your not working out of town like i am and just can`t get at it .Would you know when the big car parts swap and sale is held in Waterdown ,good luck with the build and hope to see the truck soon ...Robert
Old 06-09-2010, 07:23 PM   #41
Scott52
Scott52's Avatar
there was a swap meet in waterdown a few weeks ago, i was away working so i missed it.
i havn't had much time to work on the truck lately, a few home projects and work are taking my time. i have to get back at it and mount the front bumper, then i want to slide the motor and tranny in to see what i have to do to the firewall and floor pan
Scott
Old 06-09-2010, 07:30 PM   #42
Kabwe
Certified Car Nut
Kabwe's Avatar
Looks like you have a nice project and you are doing a great job. Keep up the good work.
Kabwe is offline   Reply With Quote
Old 06-10-2010, 11:03 AM   #43
Scott52
Scott52's Avatar
thanks, it will slowly get done
Old 06-10-2010, 12:44 PM   #44
eventytoo
nice project. That your Nytro in the backround?
eventytoo is offline   Reply With Quote
Old 06-10-2010, 12:48 PM   #45
Scott52
Scott52's Avatar
no, that 1 isn't mine, belongs to a buddy, i have an apex rtx
